I have an nano CUL plugged to usb port.
After rebooting the raspberry the device is not recognised.
Using ser2net to make it available in the LAN.
Raspberry running OSMC on it.
Same CUL is working fine - recognised after reboot - on raspberry with plain stretch running on it.
I soldered the testpin as described in various forums. This fixed the problem for normal jessie and stretch installations. but not for the OSMC .
So i assume it must be related to OSMC?
It is working abfter unplugging and new plugging in, but not after reboot.
Maybe someone having an idea.
here some logs:
[Fr Feb 23 08:24:32 2018] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
[Fr Feb 23 08:24:32 2018] usb 1-1.4: USB disconnect, device number 9
[Fr Feb 23 11:01:00 2018] usb 1-1.4: new full-speed USB device number 10 using dwc_otg
[Fr Feb 23 11:01:00 2018] usb 1-1.4: New USB device found, idVendor=0403, idProduct=6001
[Fr Feb 23 11:01:00 2018] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[Fr Feb 23 11:01:00 2018] usb 1-1.4: Product: FT232R USB UART
[Fr Feb 23 11:01:00 2018] usb 1-1.4: Manufacturer: FTDI
[Fr Feb 23 11:01:00 2018] usb 1-1.4: SerialNumber: 00000000
[Fr Feb 23 11:01:00 2018] usb 1-1.4: Detected FT232RL
[Fr Feb 23 11:01:00 2018] usb 1-1.4: FTDI USB Serial Device converter now attached to ttyUSB0
[Fr Feb 23 11:01:00 2018] usb 1-1.4: USB disconnect, device number 10
[Fr Feb 23 11:01:01 2018] usb 1-1.5: new full-speed USB device number 11 using dwc_otg
[Fr Feb 23 11:01:01 2018] usb 1-1.5: device descriptor read/64, error -32
[Fr Feb 23 11:01:02 2018] usb 1-1.5: device descriptor read/64, error -32
[Fr Feb 23 11:01:02 2018] usb 1-1.5: new full-speed USB device number 12 using dwc_otg
[Fr Feb 23 11:01:02 2018] usb 1-1.5: new full-speed USB device number 13 using dwc_otg
[Fr Feb 23 11:01:03 2018] usb 1-1.5: device not accepting address 13, error -32
[Fr Feb 23 11:01:03 2018] usb 1-1.5: new full-speed USB device number 14 using dwc_otg
[Fr Feb 23 11:01:03 2018] usb 1-1.5: device not accepting address 14, error -32
[Fr Feb 23 11:01:03 2018] usb 1-1-port5: unable to enumerate USB device
after reboot
[Fr Feb 23 11:23:09 2018] usb 1-1.5: new full-speed USB device number 4 using dwc_otg
[Fr Feb 23 11:23:09 2018] usb 1-1.5: device descriptor read/64, error -32
[Fr Feb 23 11:23:10 2018] usb 1-1.5: new full-speed USB device number 5 using dwc_otg
[Fr Feb 23 11:23:10 2018] usb 1-1.5: device descriptor read/64, error -32
[Fr Feb 23 11:23:10 2018] usb 1-1.5: new full-speed USB device number 6 using dwc_otg
[Fr Feb 23 11:23:11 2018] usb 1-1.5: device not accepting address 6, error -32
[Fr Feb 23 11:23:11 2018] usb 1-1.5: new full-speed USB device number 7 using dwc_otg
[Fr Feb 23 11:23:11 2018] usb 1-1.5: device not accepting address 7, error -32
[Fr Feb 23 11:23:11 2018] usb 1-1-port5: unable to enumerate USB device
fine after new re-plugin:
[Fr Feb 23 11:28:56 2018] usb 1-1.5: Detected FT232RL
[Fr Feb 23 11:28:56 2018] usb 1-1.5: FTDI USB Serial Device converter now attached to ttyUSB0
https://paste.osmc.tv/iwoleyuhiw
Thanks in advance
T
