My Vero 4k has gone completely nuts. The IR remote control hardly had any control! BBC iPlayer is buffering like mad. So, I decided to do a complete re-install. Booting from a microSD card didn’t work but booting from a USB drive did.
Now I cannot work out how to configure OSMC back to how it was. I find Kodi the worst interface for configuring things. I try to remove the Pictures option from the main screen but it seems determined to search for pictures instead. Removing other items worked okay.
Then I have tried to add locations for Movies and TV shows. These reside on a TrueNAS box shared as windows shares. I can browse to them on all my computers but on the Vero4K browsing gives no results.
When I try to add a share manually I then try and tell it that movies reside there. It will not let me select that option.
I seem to have added the share twice in trying to get things to work and I can’t work out how to remove the duplicate.
On the old build movies would be displayed on the main screen. Now they are not.
I have Kodi on my main PC which I use to test things. It can see all the files on the TrueNAS box. I can play iPlayer programmes with no buffering.
So, what am I doing wrong? I’ve tried searching but everything seems to want to tell me how to setup a share. I don’t need that. It is how to configure OSMC to access the shares that I am finding difficult. I expected to click browse, find my server and have the shares listed.
Also, can someone please tell me how to watch ITVX etc on OSMC.
I am so fed up of the recent issues that I’m thinking of buying an Apple TV!!!
Everything was working fine until the last update when my remote issues started. BBC iplayer programmes would work with the remote until the buffering issues started. But playing video files on the server did not respond to the remote. I could play a video but not pause, rewind or stop it.
