Hi guys,
I’ve just installed OSMC on my Raspberry Pi 2 but even if I can connect via Transmission GUI from my PC I can’t download anything because the port seems closed.
I’ve checked on my router and on that side is ok.
I’ve tried just to add an iptables rule (sudo iptables -I INPUT -p tcp --dport 51413 -j ACCEPT) but the problem still persist.
It seems strange to me because on router I’ve enable the port forwarding for the 51413 TCP port to the ip address of the OSMC Raspy (I’ve just re-checked!) and before of buying the Pi 2 I’ve used a Raspy B+ with Transmission just disabling the firewall on Raspbmc settings… I’m reusing the same ip-address of the old Raspy (static DHCP rule on my router).
Why on the old Raspy with the same ip-address was working?
