Neofetch supports osmc (ssh/console request)
just a fun fact not that essential for development but it would look nicer when loggin on to ssh as a motd and it can be customized to show either less info or more info.
fairly un-intrusive package wouldn’t requier alot of packages depends etc.
+1 for this. I think that would be a great MOTD.
could be customized to fit osmc perfectly since there are alot of options to turn on or off
Usage: neofetch --option "value" --option "value"
Neofetch is a CLI system information tool written in BASH. Neofetch
displays information about your system next to an image, your OS logo,
or any ASCII file of your choice.
NOTE: Every launch flag has a config option.
Options:
INFO:
--disable infoname          Allows you to disable an info line from appearing
                            in the output.
                            NOTE: You can supply multiple args. eg. 'neofetch --disable cpu gpu disk shell'
--os_arch on/off            Hide/Show OS architecture.
--speed_type type           Change the type of cpu speed to display.
                            Possible values: current, min, max, bios,
                            scaling_current, scaling_min, scaling_max
                            NOTE: This only supports Linux with cpufreq.
--cpu_shorthand type        Shorten the output of CPU
                            Possible values: name, speed, tiny, on, off
--cpu_cores type            Whether or not to display the number of CPU cores
                            Possible values: logical, physical, off
                            NOTE: 'physical' doesn't work on BSD.
--cpu_speed on/off          Hide/Show cpu speed.
--cpu_temp C/F/off          Hide/Show cpu temperature.
                            NOTE: This only works on Linux and BSD.
                            NOTE: For FreeBSD-based systems, you need to enable coretemp kernel module.
--distro_shorthand on/off   Shorten the output of distro (tiny, on, off)
                            NOTE: This option won't work in Windows (Cygwin)
--kernel_shorthand on/off   Shorten the output of kernel
                            NOTE: This option won't work in BSDs (except PacBSD and PC-BSD)
--uptime_shorthand on/off   Shorten the output of uptime (tiny, on, off)
--refresh_rate on/off       Whether to display the refresh rate of each monitor
                            Unsupported on Windows
--gpu_brand on/off          Enable/Disable GPU brand in output. (AMD/NVIDIA/Intel)
--gpu_type type             Which GPU to display. (all, dedicated, integrated)
                            NOTE: This only supports Linux.
--gtk_shorthand on/off      Shorten output of gtk theme/icons
--gtk2 on/off               Enable/Disable gtk2 theme/font/icons output
--gtk3 on/off               Enable/Disable gtk3 theme/font/icons output
--shell_path on/off         Enable/Disable showing $SHELL path
--shell_version on/off      Enable/Disable showing $SHELL version
--disk_show value           Which disks to display.
                            Possible values: '/', '/dev/sdXX', '/path/to/mount point'
                            NOTE: Multiple values can be given. (--disk_show '/' '/dev/sdc1')
--disk_subtitle name/mount  What information to append to the Disk subtitle.
                            'name' shows the disk's name (sda1, sda2, etc)
                            'mount' shows the disk's mount point (/, /mnt/Local Disk, etc)
--ip_host url               URL to query for public IP
--song_shorthand on/off     Print the Artist/Title on separate lines
--install_time on/off       Enable/Disable showing the time in Install Date output.
--install_time_format 12h/24h
                            Set time format in Install Date to be 12 hour or 24 hour.
TEXT FORMATTING:
--colors x x x x x x        Changes the text colors in this order:
                            title, @, underline, subtitle, colon, info
--underline on/off          Enable/Disable the underline.
--underline_char char       Character to use when underlining title
--bold on/off               Enable/Disable bold text
COLOR BLOCKS:
--color_blocks on/off       Enable/Disable the color blocks
--block_width num           Width of color blocks in spaces
--block_height num          Height of color blocks in lines
--block_range num num       Range of colors to print as blocks
BARS:
--bar_char 'elapsed char' 'total char'
                            Characters to use when drawing bars.
--bar_border on/off         Whether or not to surround the bar with '[]'
--bar_length num            Length in spaces to make the bars.
--bar_colors num num        Colors to make the bar.
                            Set in this order: elapsed, total
--cpu_display mode          Bar mode.
                            Possible values: bar, infobar, barinfo, off
--memory_display mode       Bar mode.
--battery_display mode      Bar mode.
--disk_display mode         Bar mode.
IMAGE BACKEND:
--backend backend           Which image backend to use.
                            Possible values: 'ascii', 'caca', 'catimg', 'jp2a', 'iterm2', 'off', 'sixel', 'tycat', 'w3m'
--source source             Which image or ascii file to use.
                            Possible values: 'auto', 'ascii', 'wallpaper', '/path/to/img', '/path/to/ascii', '/path/to/dir/'
--ascii source              Shortcut to use 'ascii' backend.
--caca source               Shortcut to use 'caca' backend.
--catimg source             Shortcut to use 'catimg' backend.
--iterm2 source             Shortcut to use 'iterm2' backend.
--jp2a source               Shortcut to use 'jp2a' backend.
--sixel source              Shortcut to use 'sixel' backend.
--termpix source            Shortcut to use 'termpix' backend.
--tycat source              Shortcut to use 'tycat' backend.
--w3m source                Shortcut to use 'w3m' backend.
--off                       Shortcut to use 'off' backend.
NOTE: 'source; can be any of the following: 'auto', 'ascii', 'wallpaper', '/path/to/img', '/path/to/ascii', '/path/to/dir/'
ASCII:
--ascii_colors x x x x x x  Colors to print the ascii art
--ascii_distro distro       Which Distro's ascii art to print
                            NOTE: Arch and Ubuntu have 'old' logo variants.
                            NOTE: Use 'arch_old' or 'ubuntu_old' to use the old logos.
                            NOTE: Ubuntu has flavor variants.
                            NOTE: Change this to 'Lubuntu', 'Xubuntu', 'Ubuntu-GNOME', 'Ubuntu-Studio' or 'Ubuntu-Budgie' to use the flavors.
                            NOTE: Alpine, Arch, Crux, Gentoo, OpenBSD, and Void have a smaller logo variant.
                            NOTE: Change this to 'alpine_small', 'arch_small', 'crux_small', 'gentoo_small', 'openbsd_small', and 'void_small' to use the small logos.
--ascii_bold on/off         Whether or not to bold the ascii logo.
-L, --logo                  Hide the info text and only show the ascii logo.
IMAGE:
--size 00px | --size 00%    How to size the image.
                            Possible values: auto, 00px, 00%, none
--crop_mode mode            Which crop mode to use
                            Takes the values: normal, fit, fill
--crop_offset value         Change the crop offset for normal mode.
                            Possible values: northwest, north, northeast,
                            west, center, east, southwest, south, southeast
--xoffset px                How close the image will be to the left edge of the
                            window. This only works with w3m.
--yoffset px                How close the image will be to the top edge of the
--bg_color color            Background color to display behind transparent image.
--gap num                   Gap between image and text.
                            NOTE: --gap can take a negative value which will move the text closer to the left side.
--clean                     Delete cached files and thumbnails.
SCREENSHOT:
-s, --scrot /path/to/img    Take a screenshot, if path is left empty the screen-
                            shot function will use $scrot_dir and $scrot_name.
-su, --upload /path/to/img  Same as --scrot but uploads the scrot to a website.
--image_host imgur/teknik   Website to upload scrots to.
--scrot_cmd cmd             Screenshot program to launch
OTHER:
--config /path/to/config    Specify a path to a custom config file
--config none               Launch the script without a config file
--help                      Print this text and exit
--version                   Show neofetch version
-v                          Display error messages.
-vv                         Display a verbose log for error reporting.
DEVELOPER:
 --gen-man                   Generate a manpage for Neofetch in your PWD. (Requires GNU help2man)
