Hi, I am trying to netboot OSMC/RPi2 from NFS/ubuntu server. My end goal is to boot and run multiple RPis off the server storage and never touch the SD cards again.
So far I have installed UBOOT on RPi SD and configured DHCP+TFTP on server to deliver a UBOOT script. My UBOOT script then downloads the OSMC kernel from the TFTP server and starts it. This all works fine…
The problem at the moment is that OSMC seems to be ignoring the nfs root options and trying to boot from MMC. The serial console shows:-
Linux version 3.18.13 (root@compiler1) (gcc version 4.7.3 (Buildroot 2014.05-gc065b36) ) #2 SMP PREEMPT Sat Jan 30 04:00:15 GMT 2016
Kernel command line: loglevel=8 console=ttyAMA0 ip=dhcp root=/dev/nfs nfsroot=192.168.0.10:/nfs-exports/net-boot/rpi/osmc osmcdev=rbp2
"Thu Jan 1 00:00:16 1970" "Starting OSMC installer"
"Thu Jan 1 00:00:24 1970" "Detecting device we are running on"
"Thu Jan 1 00:00:24 1970" "Mounting boot filesystem"
"Thu Jan 1 00:00:24 1970" "Trying to mount to MNT_BOOT (/mnt/boot)"
"Thu Jan 1 00:00:24 1970" "Using device->boot: /dev/mmcblk0p1 and FS: fat32"
"Thu Jan 1 00:00:24 1970" "Halting Install. Error message was: no filesystem found"
Any suggestions what UBOOT/command line options I could try next?
Thanks.
