Netfilter persistent problem after upgrade to Buster
Hi, after upgrading to Buster I got a msg: "Error: netfilter persistent "
My device is Raspberry PI 3B+.
Here are details:
 ~  systemctl status netfilter-persistent.service
    ● netfilter-persistent.service - netfilter persistent configuration
       Loaded: loaded (/lib/systemd/system/netfilter-persistent.service; enabled; vendor preset: enabled)
       Active: failed (Result: exit-code) since Mon 2020-10-19 07:45:03 CEST; 12min ago
      Process: 273 ExecStart=/usr/sbin/netfilter-persistent start (code=exited, status=1/FAILURE)
     Main PID: 273 (code=exited, status=1/FAILURE)
    Oct 19 07:45:02 osmc netfilter-persistent[273]: iptables-restore v1.8.2 (nf_tables): unknown option "--restore-mark"
    Oct 19 07:45:02 osmc netfilter-persistent[273]: Error occurred at line: 12
    Oct 19 07:45:02 osmc netfilter-persistent[273]: Try `iptables-restore -h' or 'iptables-restore --help' for more information.
    Oct 19 07:45:02 osmc netfilter-persistent[273]: run-parts: /usr/share/netfilter-persistent/plugins.d/15-ip4tables exited with return code 2
    Oct 19 07:45:02 osmc netfilter-persistent[273]: run-parts: executing /usr/share/netfilter-persistent/plugins.d/25-ip6tables start
    Oct 19 07:45:02 osmc netfilter-persistent[273]: ip6tables-restore: line 6 failed
    Oct 19 07:45:02 osmc netfilter-persistent[273]: run-parts: /usr/share/netfilter-persistent/plugins.d/25-ip6tables exited with return code 1
    Oct 19 07:45:03 osmc systemd[1]: netfilter-persistent.service: Main process exited, code=exited, status=1/FAILURE
    Oct 19 07:45:03 osmc systemd[1]: netfilter-persistent.service: Failed with result 'exit-code'.
    Oct 19 07:45:03 osmc systemd[1]: Failed to start netfilter persistent configuration.
cat -n /etc/iptables/rules.v4
|1|# Generated by iptables-save v1.6.0 on Sun Oct 18 23:03:16 2020|
|     2|*mangle|
|     3|:PREROUTING ACCEPT [4800:7100288]|
|     4|:INPUT ACCEPT [4800:7100288]|
|     5|:FORWARD ACCEPT [0:0]|
|     6|:OUTPUT ACCEPT [1524:86296]|
|     7|:POSTROUTING ACCEPT [1524:86296]|
|     8|:connman-INPUT - [0:0]|
|     9|:connman-POSTROUTING - [0:0]|
|    10|-A INPUT -j connman-INPUT|
|    11|-A POSTROUTING -j connman-POSTROUTING|
|    12|-A connman-INPUT -j CONNMARK --restore-mark --nfmask 0xffffffff --ctmask 0xffffffff|
|    13|-A connman-POSTROUTING -j CONNMARK --save-mark --nfmask 0xffffffff --ctmask 0xffffffff|
|    14|COMMIT|
|    15|# Completed on Sun Oct 18 23:03:16 2020|
|    16|# Generated by iptables-save v1.6.0 on Sun Oct 18 23:03:16 2020|
|    17|*filter|
|    18|:INPUT ACCEPT [4741:7090376]|
|    19|:FORWARD ACCEPT [0:0]|
|    20|:OUTPUT ACCEPT [1487:78680]|
|    21|:DOCKER - [0:0]|
|    22|:DOCKER-ISOLATION-STAGE-1 - [0:0]|
|    23|:DOCKER-ISOLATION-STAGE-2 - [0:0]|
|    24|:DOCKER-USER - [0:0]|
|    25|-A FORWARD -j DOCKER-USER|
|    26|-A FORWARD -j DOCKER-ISOLATION-STAGE-1|
|    27|-A FORWARD -o docker0 -m conntrack --ctstate RELATED,ESTABLISHED -j ACCEPT|
|    28|-A FORWARD -o docker0 -j DOCKER|
|    29|-A FORWARD -i docker0 ! -o docker0 -j ACCEPT|
|    30|-A FORWARD -i docker0 -o docker0 -j ACCEPT|
|    31|-A DOCKER-ISOLATION-STAGE-1 -i docker0 ! -o docker0 -j DOCKER-ISOLATION-STAGE-2|
|    32|-A DOCKER-ISOLATION-STAGE-1 -j RETURN|
|    33|-A DOCKER-ISOLATION-STAGE-2 -o docker0 -j DROP|
|    34|-A DOCKER-ISOLATION-STAGE-2 -j RETURN|
|    35|-A DOCKER-USER -j RETURN|
|    36|COMMIT|
|    37|# Completed on Sun Oct 18 23:03:16 2020|
|    38|# Generated by iptables-save v1.6.0 on Sun Oct 18 23:03:16 2020|
|    39|*nat|
|    40|:PREROUTING ACCEPT [0:0]|
|    41|:INPUT ACCEPT [0:0]|
|    42|:OUTPUT ACCEPT [0:0]|
|    43|:POSTROUTING ACCEPT [0:0]|
|    44|:DOCKER - [0:0]|
|    45|-A PREROUTING -m addrtype --dst-type LOCAL -j DOCKER|
|    46|-A OUTPUT ! -d 127.0.0.0/8 -m addrtype --dst-type LOCAL -j DOCKER|
|    47|-A POSTROUTING -s 172.17.0.0/16 ! -o docker0 -j MASQUERADE|
|    48|-A POSTROUTING -s 10.0.0.0/8 ! -d 10.0.0.0/8 -o eth0 -j MASQUERADE|
|    49|-A POSTROUTING -s 10.0.0.0/8 ! -d 10.0.0.0/8 -o eth0 -j MASQUERADE|
|    50|-A DOCKER -i docker0 -j RETURN|
|    51|COMMIT|
|    52|# Completed on Sun Oct 18 23:03:16 2020|
Looks like something may have changed in the newer version of iptables and that the --restore-mark option is no longer valid.
Indeed, this is how it looks like. I am not strong at networking though. Not sure how it should be handled properly. Should the records that are using --restore-mark be deleted?
I’d try that and see if it works. It can’t hurt.
I’m not very familiar with iptables, so hopefully someone else can chime in here.
Seems that it is part of iptables-extentions
https://manpages.debian.org/buster/iptables/iptables-extensions.8.en.html
Try sudo modprobe xt_connmark and see if that helps.
It didn’t
~  sudo modprobe xt_connmark
 ~  sudo iptables-restore < /etc/iptables/rules.v4
I think that parameter is deprecated in iptables now.
Thanks Sam. Can someone please post here how the *mangle section should look like? I tried to comment out those lines that are using the -mark parameters but it failed on the COMMIT command.
I used:
sudo update-alternatives --config iptables
to switch to iptables legacy. Everything works like a charm.
I did change to iptables legacy but netfilter-persistent stil has error:
root@osmc:/etc/modprobe.d# systemctl status netfilter-persistent.service
  • netfilter-persistent.service - netfilter persistent configuration
    Active: failed (Result: exit-code) since Mon 2020-10-19 21:16:42 CEST; 9min ago
    Process: 20074 ExecStart=/usr/sbin/netfilter-persistent start (code=exited, status=1/FAILURE)
    Main PID: 20074 (code=exited, status=1/FAILURE)
Oct 19 21:16:42 osmc systemd[1]: Starting netfilter persistent configuration…
Oct 19 21:16:42 osmc netfilter-persistent[20074]: run-parts: executing /usr/share/netfilter-persistent/plugins.d/15-ip4tables start
Oct 19 21:16:42 osmc netfilter-persistent[20074]: run-parts: executing /usr/share/netfilter-persistent/plugins.d/25-ip6tables start
Oct 19 21:16:42 osmc netfilter-persistent[20074]: ip6tables-restore: line 6 failed
Oct 19 21:16:42 osmc netfilter-persistent[20074]: run-parts: /usr/share/netfilter-persistent/plugins.d/25-ip6tables exited with return code 1
Oct 19 21:16:42 osmc systemd[1]: netfilter-persistent.service: Main process exited, code=exited, status=1/FAILURE
Oct 19 21:16:42 osmc systemd[1]: netfilter-persistent.service: Failed with result ‘exit-code’.
Oct 19 21:16:42 osmc systemd[1]: Failed to start netfilter persistent configuration.
Seems to have issue with ip6tables rules, whats the output of:
sudo cat -n /etc/iptables/rules.v6
Thanks Tom.
Sorry, I just figured out that I have to switch to iptables legacy for IPv4 and IPv6 separately. I run command:
sudo update-alternatives --config ip6tables
and now it works.
Thank you.
