I am using the netflix add-on from “asciidisco” which has been working well for a long time until recently this error message pops up (as per pic attachment). I have no idea how to resolve the matter but I am guessing it has something to do with netflix causing the add-on to “break” because of some change.
Any help would be appreciated.
reproduce the issue
My first suggestion is change Netflix addon, asciidiscos version is not updated regularly these days. I recommend CastagnaIT Repository for KODI 18.x LEIA - repository.castagnait-1.0.1.zip
There also a repository for Matrix.
This version is actively being developed and is the one I used in my netflix_prep script found here on the forum [HOW-TO ALL PLATFORMS]Can I use Netflix on OSMC?(post 4) - #4 by joakim_s
