So I just installed netflix and once I put in the credentials the screen is now in a forever loading screen (at least 5 min and still going) any idea why netflix won’t load?
I followed this page for the steps under OSMC
This topic probably aligns with another post, but I wasn’t sure where to put it.
Update
If I create a shortcut from the home menu to my account it works just fine. The loading screen only appears when I try to load Netflix through add-ons.
What device are you using?
It could be an issue with the Inputstream Adaptive add-on.
Some logs may help.
https://paste.osmc.tv/jaxofoxuyu
Hopefully this helps, I’m still unfamiliar with the log process. I opened the add-on at 04/10/21 16:44 and let it sit loading for 30ish seconds.
Can you enable debug logging?
Apologies, read your post too quickly – current inputstream issues only affect playback, so the add-on itself should be working OK.
reproduce the issue
Here is the new log
https://paste.osmc.tv/atigelifew
I tried to open the netflix add-on just as it turned 17:04 and let it load for about a minute before returning to the home screen.
