Netflix on Rpi3 + OSMC18 - Error
I’m trying install Netflix on my RPi3 under OSMC 18.RC1 but i have an error message
I have use this tutorial:
My log:
http://paste.osmc.tv/ekapadadeb.vhdl
Who can help me ?
Rgds
Akhlan
YOU can help you. Have you searched for and tried the tutorial from this forum before trying to use tutorials that are likely not exactly relevant for the platform?
It’s more easy for me a French tutorial…
Are you sure you have v18 installed? If you go into System Info in Settings, it will tell you in the bottom right corner.
I would suggest you look at the instructions here?
