Yes. I get all that. I see the background stuff starting and I am not connecting through a VPN. This is what ends up in thoe log:
2020-10-01 19:15:09.172 T:3528450784 ERROR: [plugin.video.netflix (0)] An error has occurred in the library auto update: HTTPSConnectionPool(host=‘www.netflix.com’, port=443): Max retries exceeded with url: /api/shakti/vff980d5b/metadata?materialize=false&withSize=false&isVolatileBillboardsEnabled=true&original_path=%2Fshakti%2Fvff980d5b%2FpathEvaluator&authURL=1600355035749.ESEi37JIbB0Vu45T6k0vF4pr0pQ%3D&isTop10Supported=true&movieid=81019069&routeAPIRequestsThroughFTL=false&categoryCraversEnabled=false&drmSystem=widevine&_=1601568909055 (Caused by NewConnectionError(‘<urllib3.connection.VerifiedHTTPSConnection object at 0xe8198cb0>: Failed to establish a new connection: [Errno -2] Name or service not known’,))
2020-10-01 19:15:09.186 T:3528450784 ERROR: [plugin.video.netflix (0)] Traceback (most recent call last):
File “/home/osmc/.kodi/addons/plugin.video.netflix/resources/lib/kodi/library.py”, line 220, in auto_update_library
clear_on_cancel)
File “/home/osmc/.kodi/addons/plugin.video.netflix/resources/lib/kodi/library.py”, line 293, in _update_library
notify_errors=show_prg_dialog):
File “/home/osmc/.kodi/addons/plugin.video.netflix/resources/lib/kodi/library_tasks.py”, line 42, in execute_library_task
jobs_data = self.compile_jobs_data(videoid, task_type, nfo_settings)
File “/home/osmc/.kodi/addons/plugin.video.netflix/resources/lib/utils/logging.py”, line 164, in timing_wrapper
return func(*args, **kwargs)
File “/home/osmc/.kodi/addons/plugin.video.netflix/resources/lib/kodi/library_tasks.py”, line 109, in compile_jobs_data
metadata = self.ext_func_get_metadata(videoid, True) # pylint: disable=not-callable
File “/home/osmc/.kodi/addons/plugin.video.netflix/resources/lib/services/nfsession/nfsession_ops.py”, line 191, in get_metadata
metadata_data = self._metadata(video_id=parent_videoid), None
File “/home/osmc/.kodi/addons/plugin.video.netflix/resources/lib/common/cache_utils.py”, line 84, in wrapper
output = func(*args, **kwargs)
File “/home/osmc/.kodi/addons/plugin.video.netflix/resources/lib/services/nfsession/nfsession_ops.py”, line 209, in metadata
'‘: int(time.time() * 1000)})
File “/home/osmc/.kodi/addons/plugin.video.netflix/resources/lib/services/nfsession/session/access.py”, line 83, in get_safe
return self.get(endpoint, **kwargs)
File “/home/osmc/.kodi/addons/plugin.video.netflix/resources/lib/services/nfsession/session/http_requests.py”, line 38, in get
**kwargs)
File “/home/osmc/.kodi/addons/plugin.video.netflix/resources/lib/services/nfsession/session/http_requests.py”, line 49, in _request_call
return self._request(method, endpoint, None, **kwargs)
File “/home/osmc/.kodi/addons/plugin.video.netflix/resources/lib/services/nfsession/session/http_requests.py”, line 65, in request
data=data)
File “/home/osmc/.kodi/addons/script.module.requests/lib/requests/sessions.py”, line 546, in get
return self.request(‘GET’, url, **kwargs)
File “/home/osmc/.kodi/addons/script.module.requests/lib/requests/sessions.py”, line 533, in request
resp = self.send(prep, **send_kwargs)
File “/home/osmc/.kodi/addons/script.module.requests/lib/requests/sessions.py”, line 646, in send
r = adapter.send(request, **kwargs)
File “/home/osmc/.kodi/addons/script.module.requests/lib/requests/adapters.py”, line 516, in send
raise ConnectionError(e, request=request)
ConnectionError: HTTPSConnectionPool(host=‘www.netflix.com’, port=443): Max retries exceeded with url: /api/shakti/vff980d5b/metadata?materialize=false&withSize=false&isVolatileBillboardsEnabled=true&original_path=%2Fshakti%2Fvff980d5b%2FpathEvaluator&authURL=1600355035749.ESEi37JIbB0Vu45T6k0vF4pr0pQ%3D&isTop10Supported=true&movieid=81019069&routeAPIRequestsThroughFTL=false&categoryCraversEnabled=false&drmSystem=widevine&=1601568909055 (Caused by NewConnectionError(’<urllib3.connection.VerifiedHTTPSConnection object at 0xe8198cb0>: Failed to establish a new connection: [Errno -2] Name or service not known’,))
