I have my Vero 2 set to a static MAC IP address on my router, I have tried with it disabled as well. I need to restart my ethernet adapter every time I reboot or switch into android and back into OSMC. I obviously didn’t face the issue with android on my pi2 or 3, but I didn’t have the issue with rebooting, is it a soft reboot and not rebooting the network interface? is there a way I could add that?
To get a better understanding of the problem you are experiencing we need more information from you. The best way to get this information is for you to upload some logs. You can learn more about how to submit a useful support request here.
@yknivag, does it create new logs on every start up and store previous ones?
All logs will be cleaned with reboot, only fr Kodi one copy of the previous session will be retained
