Ah ok, well I couldn’t see any other log where it went? Where should the component logging end up?
Also not sure why the above code is half disappeared, altho I’m writing this on an iPhone which doesn’t help.
My sincere apologies we had many threads with people having access problems after the update that I didn’t checked the details of your problem and thought you can not access.
So let’s reset ourselves and start from scratch:
I had similar problems. Try SMB mount from commandline (mount.cifs) and play movie from that mounted directory.
Thanks fzinken. All logging cancelled and below is the results:
I ran iperf3 from osmc to both the server and to my PC, with each both being client and server. It gives a fairly consistent 93-95Mbit/s.
However trying to copy a file from the server to OSMC is much slower. I tried a number of different files and used both the SD card and USB drive and only averaged around 1-1.5Mb/s (both timed and from the speed estimate in kodi)
Thanks Beam for your input, how would I mount a Smb share from the cli? Isn’t CIFS part of smbv1? or am I getting confused (easily done!)
I am still wondering how that can be related to the December Update.
Anyhow maybe try the fstab based mount as @Beam suggested.
Details are here
Well it was all working fine before the update, however I will try to mount one of the shares and see if the performance is better, although its not ideal as I have a Mysql database and if I change all the shares its a going to be a pain to have to rescan all of the media!
Well first check if it makes a difference. If it works with fstab mounting that you can use path substitution to match the Database entry
http://kodi.wiki/view/Path_substitution
Hey guys. Sorry for the delay,I’ve been away with work.
I’ve had a good play around with lots of different settings and I’ve found that it was to do with an add on that I’ve been using. I use Watchdog to keep all the media updated, I found disabling this fixed the issue. On further investigation it turns out my wife had plugged in the old Rpi2 to watch some tv and so we had two devices constantly checking the sources for updates. As such the strain of this meant SD shows played ok but the HD didn’t have the bandwidth. Thanks for all your help though!
On a separate issue osmc popped up saying that an update has failed to install and to post on the forums. Shall I open a new thread for it?
I tried using the cli but that had an error as well.
Yes open new thread and add grab-logs -A output
Recently i had face some similar issue, after read your thread it could be related with WatchDog since i use it as well and yesterday i noticed it was taking a lot to update just a couple of Movies/TVSeries
My thread is in case is useful too: SMB issue since last upgrade - #18 by Tom_Doyle
Thanks for sharing the link I will check and hope it helps. ![]()
