Yes that’s the 1, I do appreciate the help
Ok this is a bit weird, I can only see my Nas files on zeroconf in vero, not anything else, I don’t know what this is but I’m guessing this maybe the problem, I’m used to using SMB but if I click that nothing happens
With smb you can no longer browse for a server. You have to enter the full path with username and password as explained in the link I gave you (which you don’t seem to have clicked). It’s been discussed many times in this forum so have a search around.
I did click on it and have had a good read, thanks
Ive set up NFS so far so good but now I’m stuck, as per photo when I click volume 1 nothing happens, so what’s the next step to add my films? I was expecting to click volume and then the films appear then I add them so I’m still going wrong somewhere
Files won’t appear when adding a location as a source, only folders. That’s intended.
And I thought I was getting somewhere
