I have new Vero4k+ with DVB-T tuner from osmc.tv, in dmesg I found:
[ 3.036935] usb 1-1: Product: dvbt2
[ 3.036940] usb 1-1: Manufacturer: astrometadvbt2
[ 4.242957] usb 1-1: dvb_usb_v2: found a 'OSMC Engineering DVB-T2' in warm state
[ 4.330145] usb 1-1: dvb_usb_v2: will pass the complete MPEG2 transport stream to the software demuxer
[ 4.330182] dvbdev: DVB: registering new adapter (OSMC Engineering DVB-T2)
[ 4.331260] dvbdev: dvb_create_media_entity: media entity 'dvb-demux' registered.
[ 4.403707] i2c i2c-1: cxd2841er_attach(): attaching CXD2837ER DVB-C/T/T2 frontend
[ 4.403733] usb 1-1: DVB: registering adapter 0 frontend 0 (Realtek RTL2832 (DVB-T))...
[ 4.403756] dvbdev: dvb_create_media_entity: media entity 'Realtek RTL2832 (DVB-T)' registered.
[ 4.403906] usb 1-1: DVB: registering adapter 0 frontend 1 (Sony CXD2837ER DVB-T/T2/C demodulator)...
[ 4.403921] dvbdev: dvb_create_media_entity: media entity 'Sony CXD2837ER DVB-T/T2/C demodulator' registered.
[ 4.508756] rc rc1: OSMC Engineering DVB-T2 as /devices/c9000000.dwc3/xhci-hcd.0.auto/usb1/1-1/rc/rc1
[ 4.508984] input: OSMC Engineering DVB-T2 as /devices/c9000000.dwc3/xhci-hcd.0.auto/usb1/1-1/rc/rc1/input5
[ 4.511545] rc rc1: lirc_dev: driver ir-lirc-codec (dvb_usb_rtl28xxu) registered at minor = 1
[ 4.511561] usb 1-1: dvb_usb_v2: schedule remote query interval to 200 msecs
[ 4.520249] usb 1-1: dvb_usb_v2: 'OSMC Engineering DVB-T2' successfully initialized and connected
[ 4.520376] usbcore: registered new interface driver dvb_usb_rtl28xxu
[ 19.823634] usb 1-1: DVB: adapter 0 frontend 0 frequency 0 out of range (174000000..862000000)
TvHeadend found only 2 muxes with total of 8 channels. So I tried another tuner (bought 2 years ago from osmc.tv too):
[ 4.303444] usb 1-1: DVB: registering adapter 0 frontend 0 (Realtek RTL2832 (DVB-T))...
[ 4.303467] dvbdev: dvb_create_media_entity: media entity 'Realtek RTL2832 (DVB-T)' registered.
[ 4.303624] usb 1-1: DVB: registering adapter 0 frontend 1 (Panasonic MN88473)...
[ 4.303639] dvbdev: dvb_create_media_entity: media entity 'Panasonic MN88473' registered.
And now 63 channels found with exactly the same settings. Is the new one bad piece or has just low gain/sensitivity?
I tried both tuners plugged directly to antena and through splitter but it had no effect.
Thanks.
BTW: What to create DVB-T forum category?
