New issue certain videos slow motion and audio glitching
I have been using it for years and certain video are now playing with an issue, they play in what seems like slow motion or major frame skipping with the audio glitching as well.
Some video play fine. It might be a single codec causing it like AAC for example. I am not sure, I have not been able to pint point the exact problem.
I tested further and music is glitching as well. Some sort of audio problem I suspect.
I found the issue, I must have set the resolution to 4k and forgot about it. As I have set it back to 1080p and it plays fine now. I can’t even remember changing it but I probably did when I was messing with skins/settings.
Sorry!
We recommend people with 4K TVs set their user interface (UI) to 1080p. Kodi’s UI is not optimized for 4K yet and this can put unnecessary demands on your device and can lead to a suboptimal picture quality, as well as potentially cause other issues.
The settings we recommend are as follows…
Settings>System>Display>Resolution> 1920x1080p
Settings>System>Display>Whitelist> (empty) *
Some televisions may also need, or benefit from, the following being set…
System>Display>Force 4:2:2 colour subsampling> (enable)
With the above settings your UI will be output in Full HD and your 4K content will be output in 4K.
*Information regarding the whitelist can be found here. If you have any doubt, feel free to upload some logs so we can verify that your settings are indeed correct.
