I recently replaced my old router (TP-Link Archer C7) with a newer one (TP-Link Archer C80).
Everything in my home network was working fine until I went to play my Vero 4K+.
I realized I had to redo my sources so I removed my old sources and attempted to add them fresh. I use NFS sharing via my Synology NAS.
For some reason it took hours to scan and add my content to the library. When it did, the videos were lagging and juddering. My router firmware and Vero were all updated so I was confused. I checked all the IP addresses and router settings and everything looked fine.
So I reinstalled OSMC fresh with the latest version.
Same problem.
I reinstalled an earlier version of OSMC. Same problem.
Then I hooked my old router back up and everything worked fine. The remote control commands were instant and snappy, library sources scanned and updated quickly without issue, and everything played smoothly again.
I tried plugging in the new router again, and same problem as before.
So I’m stumped. I’m not sure what sort of networking issue is happening or what router/NAS/Vero setting I need to adjust.
I don’t know how to use any command lines or do debugging or anything like that so I’m hoping the answer is obvious and I’m just missing it.
Any help would be super appreciated!
