So I got a new TV (4K Sony) and started getting this weird issue after a few days of use. First everything was fine, but now the Vero 4K+ won’t send a signal unless I cut the power and turn it back on.
Unplugging and replugging the HDMI cable doesn’t work. Already turned off all Link operations on the TV side, disabled CEC, enabled and disabled HPD Lock on the Vero, but there must still be something else.
Have you tried another HDMI cable?
Suggest to provide some logs.
Are there any drives connected to the Vero? Is the red cross on the Vero turning on?
Yeah, tried different cables. I’ll try to get the logs when I get home tonight.
Yes, the same HDD is connected as before. It comes on with the Vero and the red cross comes on, then turns off like normal, so the Vero is definitely on, just no signal.
Is the drive self powered, or is the Vero powering it? If the Vero is powering it then it’s probably the drive causing the issue. You will need a powered USB hub for the drive as the Vero is not designed to handle powering USB drives.
It’s self powered. Never had problems with the drive.
Then we need to see logs to help find the problem.
reproduce the issue
upload the log set (all configs and logs!) either using the
I have the same issue with a Sony TV since updating to 19.1. No such problem before.
I will try to provide logs the next time it happens.
You replied to an issue from over a year ago. I seriously doubt that it is in any way related. Please start a new thread, with logs when you are ready to have us try and help you track down the issue.
Yes, I am sorry, I found a recent relative topic. Thanks.
