Hi there!
First post from a Newbie.
I took the plunge and got myself a Vero 4K+ for the combined possibilities of 4K HDR and 3D instead of a my regular RPI 3B+ for 3D and Plexapp on TV for the 4K stuff.
The Vero plays 4K content flawless and - I didn’t think this would make such a difference - 3D MVC PQ is from another league compared to the Pi; that much better!
The only problem I have is that whatever you throw at the RPI 3B+ regarding 3D content just works in contrast to the Vero (my experience). That could be a rookie mistake (hopefully it is) or perhaps require some fiddling or simply doesn’t work. To be honest, for the most part they are subtitle related and - my bad - I’m not a native english speaker so I do need them most of the time. As the 3D capabilities probably are important to a fair portion of Vero users it might be handy to get some sort of sticky or wiki regarding this topic to guide users along the adventurous 3D path.
Some problems I encounter on Vero 4K+ 19.4:
1920x1080p (3D SBS), -(3D TAB) and -(3D FP) settings won’t be properly saved in guisettings.xml, so screen calibration doesn’t survive a reboot. The first two don’t allow a sceen calibration anyway because it scrambles the screen.
3D MVC FP, srt screen position adjustment won’t be saved (see 1st point) and (big bummer) PGS depth adjustment not working.
3D TAB, srt screen position adjustment won’t be saved (see 1st point) and (bigger bummer) PGS bug sometimes text scaled wrong with off screen placement.
Can these issues be solved? That would be awsome because there is no going back ![]()
