Linux bed1 4.9.269-56-osmc
First run:
sudo apt install kodi-pvr-nextpvr
Extracting templates from packages: 100%
(Reading database … 38676 files and directories currently installed.)
Removing vero3-device-osmc (1.5.2) …
WARNING: You have tried to remove a package that is essential to OSMC’s operation.
To undo these changes, run ‘sudo apt-get -f install’.
dpkg: error processing package vero3-device-osmc (–remove):
installed vero3-device-osmc package pre-removal script subprocess returned error exit status 1
dpkg: too many errors, stopping
vero3-device-osmc
Processing was halted because there were too many errors.
Second run:
osmc@bed1:~/programs/m3u-epg-editor$ sudo apt install kodi-pvr-nextpvr
Reading package lists… Done
Building dependency tree… Done
vero3-mediacenter-osmc : Conflicts: kodi
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
