I have been using Hanewin NFS on my Win 10 Computer for years, because I was advised by people on here to go with NFS, now but it just doesn’t work correctly… or not at all…
It used to work fine, it hasn’t anymore for more than a year.
Before going into details, I use Comodo Firewall (even with it turned off or uninstalled it makes no changes) and Veracrypt for my disks (previously Bitlocker, on or off makes no difference), neither influence my connectivity but I want to mention them before someone says it might be that.
The big issue I have with Hanewin NFS that I can have 3 video files, all from the exact same quality and codec, but have 1 or 2 not approachable through my Vero. The strange thing is that it isn’t consistent.
Lets say I have video A, B, C, and D.mp4, right now video A, B, and D work perfect, but when I try to access video C it gives a library error, file not found.
When I go to the hosting Win 10 computer and try to play A, B, C and D all of them work.
Sometimes playing them in Win 10 helps them start on my Vero too but that is pretty rare.
Now the weirdest thing of it all. A, B and D can work just fine today while C does not, then tomorrow A, B, C, and D all work, but the day after only A and D work. It makes no sense.
If anything I want to fix this problem, it’s not my Hanewin, all connections seem to be good but loading them and checking the kodi log it says the NFS could not be opened, while it’s accessible for other things.
I contacted Hanewin and they could not find an issue with anything, it could only be the media player.
This is my complete hanewin export
# exports example
# please read doc for a list of all options
# drive letters should be in upper case, because file-id returns upper case
# by default (option setting) they are mapped to lower case for clients
# Option -range restricts access to specified address range
# a list of addresses restricts to these clients only
# Option -readonly prohibits create/write/delete
# Option -name:<x makes folder for clients avalailable as /<x>
# Option -maproot:<uid maps unix root to specified <uid>
# without it uid root - uid NOBODY
# Option -alldirs allows clients to mount folder or any subfolder
# Use UNC path specification for access to remote drive
# Hidden volumes without a drive letter can be mounted by volume GUID
#C:\ftp -range 192.168.1.1 192.168.1.10
#C:\video -readonly 192.168.1.1 192.168.1.4 192.18.1.23
#C:\server -alldirs -name:server -maproot:0 -range 192.168.1.1 192.168.1.30
#\\router\FRITZ.NAS\SanDisk-U3CruzerMicro-00 -name:fritz
#\\?\Volume{6afa3aa3-1b38-11e6-a140-0000fbaa0005}\ -name:drive1
t:\Shows -readonly 192.168.1.106
v:\Movie -readonly 192.168.1.106
r:\Anime -readonly 192.168.1.106
t:\Shows -name:Shows -readonly 192.168.1.105
v:\Movie -name:Movies -readonly 192.168.1.105
r:\Anime -name:Anime -readonly 192.168.1.105
q:\Audiobooks -name:Audiobooks -readonly 192.168.1.108
u:\Movies -name:Films -readonly 192.168.1.105
u:\Movies -name:Films -readonly 192.168.1.106
I tried turning UDP off and INODE reset on in Hanewin but that does not help either. I use the latest version but have had this problem for a long time.
Out of desperation I tried to move from NFS to SMB because a mod on here said it would work just as well. I configured it in my firewall and nothing is blocked anymore, when I go to my own \ip on my computer\ I can reach my files but when I try to connect to SMB on my OSMC I get Error 2 no connection found so I can’t access my media through that way either.
I tried everything I could think of, for weeks now. Following guides and advice.
I have no password set on my Win 10, I turned off password requirement in windows Advanced Sharing (the 128 bit encryption is still on but without a password) and I have no real username (and it doesn’t ask for it when I try to browse the shares on the Win device either).
I’m not a huge tech guru so I might need a step by step (including how to properly share) guide but I don’t think I messed up.
I have 2x Vero 4K+, a normal Ver and a Raspberry Pi 3 running but none of them work properly, the best working devices are on NFS, but half of the files don’t play most of the time so I have to wait until they do again, it’s completely random.
