NFS Mount
Hello,
Unfortunately i have a new problem - i cant mount my Synology-NAS share as an media source.
I try the same way I’ve added the share many times on other Kodi devices:
Add source -> NFS -> NAS-IP -> Media-Share
But at this point i cannot “enter” the Media-Share.
I have already added NFS permissions to Vero’s static IP, disabled the Synology firewall and even reset my NAS…
Is there anything special to consider at Vero / OSMC or differently than with other Kodi devices?
Thanks in advance!
  • enable component-specific logging for all components
  • enable event logging and notification event logging
OSMC skin screenshots:
Hello,
i have created a log: https://paste.osmc.tv/digehepuxa
Thanks for checking!
Failed to open(//) opendir call failed with “NFS: READDIRPLUS of / failed with NFS3ERR_ACCES(-13)”
Have you nfs4 enabled? if so try disabling it?
You may want to consider addings nfs shares as follows:
Thanks Tom.
Thanks for checking Tom!
Could you tell me how to check if nfsv4 is enabled and how to disable?
On DSM 6.2.3-25426, its located:
Control Panel -> File Services -> SMB/AFP/NFS
Under the NFS Section, below the Enable NFS tickbox, there is another tick box Enable NFSv4.1 support; if its ticked un-tick it.
Thanks Tom.
Thanks Tom!
NFSv1 is not enabled on DSM.
I have followed the instructions to mount the share via autofs and the share is mounted in the filesystem afterwards:
osmc@osmc:~$ mount | grep Vol1
/etc/auto.nfs.shares on /mnt/NAS/Vol1 type autofs (rw,relatime,fd=6,pgrp=2468,timeout=15,minproto=5,maxproto=5,direct,pipe_ino=16686)
But i can only list the content with sudo:
osmc@osmc:~$ sudo ls -lah /mnt/NAS/Vol1
drwxrwxrwx  12 root root  4.0K Apr 30 19:22 .
dr-xr-xr-x   3 root root  4.0K Jun 19 14:07 ..
drwxrwxrwx  24 1024 users 4.0K Jun 14 16:26 <Foldername>
not as user osmc:
osmc@osmc:~$ ls -lah /mnt/NAS/Vol1
ls: cannot open directory '/mnt/NAS/Vol1': Permission denied
In the osmc GUI i can also not enter the share. Is there a user / permissions issue and i have to do something on the Synology? This are the current user:
admin@DS418j:/$ cat /etc/passwd
admin:x:1024:100:System default user:/var/services/homes/admin:/bin/sh
anonymous:x:21:21::/nonexist:/usr/bin/nologin
avahi:x:84:84::/:/bin/false
bind:x:53:53::/:/usr/bin/nologin
daemon:x:2:2::/:/bin/sh
dbus:x:81:81::/:/usr/bin/nologin
dovecot:x:143:143::/dev/null:/usr/bin/nologin
FileStation:x:179652:179652::/var/packages/FileStation/target:/sbin/nologin
Flo:x:1026:100::/var/services/homes/Flo:/sbin/nologin
ftp:x:21:21::/nonexist:/usr/bin/nologin
guest:x:1025:100:Guest:/nonexist:/usr/bin/nologin
http:x:1023:1023::/var/services/web:/bin/false
ldap:x:439:439::/var/lib/openldap:/usr/bin/nologin
lp:x:7:7::/var/spool/lpd:/bin/sh
mysql:x:66:66::/var/services/mysql:/bin/false
nobody:x:99:99::/:/bin/false
ntp:x:87:87::/var/lib/ntp:/bin/false
OAuthService:x:226662:226662::/var/packages/OAuthService/target:/sbin/nologin
postfix:x:125:125::/dev/null:/usr/bin/nologin
postgres:x:55:55::/var/services/pgsql:/bin/sh
root:x:0:0::/root:/bin/ash
rpc:x:32:32::/dev/null:/bin/false
SynoFinder:x:195341:195341::/var/packages/SynoFinder/target:/sbin/nologin
system:x:1:1::/usr/syno/synoman:/usr/bin/nologin
Thanks in advance!
Assuming that’s a typo? As it should be NFSv4.1.
Sounds like a permissions issue server side, What settings do you have for Privilege & Squash for nfs permissions on the synology?
Thanks Tom.
YEAH!!! :slight_smile:
For this export i have now assigned all users to guest via Squash and it works now! I dont know why this is not necessary for the other exports but it doesn’t matter, it works now - Thank you!!!
I thank you for this thread and explanations
more détails for Synology DSM end users :
fix it with in Shared folders > Right Click on one > Modify > NFS permissions > Select One > Modify > Squash
