I’ve been using NFS shares from a Windows 10 PC for quite a while now (Hanewin nfsd).
It has suddenly decided to stop working. I have tried connections on wireless and wired (usual connection).
I have disabled the firewall to no avail.
I get the sad face or a complete crash when trying to play media and the scan on startup just sits at 0%.
Disabling the firewall momentarily showed the first frame of a video but then crashed again.
None of the media I’ve played has issues, indeed previously played media also doesn’t work.
I have Kodi installed on a FireTV stick in another room accessing exactly the same files and shares and it has no issues.
The logs are here https://paste.osmc.tv/epakumagaz please ignore errors like this as I’ve recently moved a drive but not updated the share:
ERROR: NFS: Failed to mount nfs share: /music01 (mount/mnt call failed with "RPC error: Mount failed with error unknown mount stat(19) Numerical result out of range(34)")
21:25:11.805 T:3707761408 ERROR: GetDirectory - Error getting nfs://192.168.1.65/music01/Music/(hed) Planet Earth/(hed)pe/
So it’s only that one file that fails? Try copying it directly to the Vero and see if it plays then.
If it does not play, please reboot the Vero twice, that will clear all of the previous errors and may help see what’s really happening. Then play and post logs.
No, none of the files works as you quoted. I can select a file, get the spinning icon and then a sad face. In fact when I turned on debug I also got a sad face when navigating back to the main screen. And as already said it is unable to do it’s startup scans to refresh the library.
@sam_nazarko@fzinken that NFS issue seems to have cured it Strange that the 17.6 Kodi install on the FireTV Stick is fine without those settings.
However I’ve discovered a problem file which I’ll get more details on later. The file plays fine in MPC-HD, but will give it a go on the FireTV stick and do some further diagnosis and raise as a separate ticket
