Thanks for your great guide. Everything worked pretty smoothly.
I included two nfs shares in /etc/fstab with the same parameters mentioned in the guide.
On my server the shares are: /mnt/large/mm and the other share is /mnt/large/omm. In my fstab, they are mounted as
192.168.1.20:/mnt/large/mm /mnt/Server_Movies nfs noauto,x-systemd.automount 0 0 and
192.168.1.20:/mnt/large/omm /mnt/Server_Other_MM nfs noauto,x-systemd.automount 0 0
The sudo mount -a command works flawlessly and also both systemctl commands work.
However, when I reboot the Vero4K from the command line, I only have the second share (omm in /mnt/Server_Ohter_MM), the first share (/mnt/large/mm on my server) is not mounted in /mnt/Server_Movies.
When I issue the systemctl commands, they (both) are mounted correctly.
Am I doing anything wrong?
Thanks for helping!
Georg
