I re-imaged my vero4k the other day. Continued playing with the settings today, somewhere I think I screwed up something…
I can browse through my movie sources, but the videos won’t start.
Tried rebooting both NAS (synology) and the Vero4K.
log is uploaded: https://paste.osmc.tv/anigokoreq
Could you help out?
From the command line, please provide the output of:
showmount -e 192.168.178.15
Thanks Tom.
Export list for 192.168.178.15:
/volume1/Schijfje 192.168.178.32
Ok that looks good. Are you using a firewall on vero4k or the nas?
Thanks Tom.
No, no firewalls in use on the vero or the synology
Thanks Jeroen
Are you able to manually mount the shares? Please try the following from the command line:
sudo mkdir /mnt/Movies
sudo mount -vt nfs 192.168.178.32:/volume1/Schijfje/Movies /mnt/Movies
Please provide the output?
Thanks Tom.
Hi Tom,
I think something was wrong with the wireless adaptor. I noticed in my wifi management that the vero4k was experiencing some drops in connectivity. Reconnected it to another AP and now it all seems to work fine again.
Sorry for the inconvenience, but thanks for the help!
greets, Jeroen
No worries. Glad to here it’s sorted.
Thanks Tom.
