I’ve had an intermittent issue for several versions now.
the nfs mounts (mounted via autofs) will occasionally stop showing the contents of some subdirectories underneath it.
192.168.1.2:/music-share /music-share nfs _netdev,noauto,x-systemd.automount 0 0
for example my main genre directory stopped “seeing” the genres under it:
ls /music-share/ALL-MUSIC/Genres
osmc@osmc2:~$ ls -al /music-share/ALL-MUSIC/Genres
total 4
drwxrwxrwx 1 osmc osmc 4096 Jun 27 23:52 .
drwxrwxrwx 1 osmc osmc 223 Sep 14 00:19 …
osmc@osmc2:~$
but if I specify one of the actual genres I know are underneath it, it can still see those contents
ls -al /music-share/ALL-MUSIC/Genres/Gothic\ Synthpop/
total 404
drwxrwxrwx 1 osmc osmc 4096 Jun 25 17:18 .
drwxrwxrwx 1 osmc osmc 4096 Jun 27 23:52 …
drwxrwxrwx 1 osmc osmc 4096 Sep 14 22:05 And One
drwxrwxrwx 1 osmc osmc 4096 Sep 14 22:06 Apoptygma Berzerk
…etc
if I reboot, then everything is fine, for a while at least.
The issue seems to be most prone to occur when I tell it to scan one of my Genre sub-directories (I added each …/Genres/ as a separate source), occasionally while scanning one of those sub-directories, it will stop seeing any of the artist sub-directories under that genre (but other genres still show fine)
#sudo -o remount /music-share
does not seem to clear it up. a reboot always does though.
I’m a bit baffled by this behavior, as I would expect the whole mount disappear, not just some random directories under it.
dmesg doesn’t show complaints, and there doesn’t seem to be /var/log/syslog being written, so I’m not sure where to look for the errors.
