Hi DBMandrake
I did my test om an 3Gig mv file but for the simplicity I redid alla tests with a smaller (45K) textfile. The results are the same. Is there a way to upload pcap files?
I’ve tried tcp to no avail and also with both 8 och 32K mount options. nfs v3 is defaulting to 16K on udp and to my surprise to 132K on TCP. I’m connected with gig on all my devices but the rbpi2
UDP mount
192.168.10.24:/mnt/stripe/serier on /mnt/Serier type nfs (ro,noatime,vers=3,rsize=16384,wsize=16384,namlen=255,soft,proto=udp,timeo=11,retrans=3,sec=sys,mountaddr=192.168.10.24,mountvers=3,mountport=816,mountproto=udp,local_lock=none,addr=192.168.10.24)
TCP mount
192.168.10.24:/mnt/stripe/serier on /mnt/Serier type nfs (ro,noatime,vers=3,rsize=131072,wsize=131072,namlen=255,soft,proto=tcp,timeo=600,retrans=2,sec=sys,mountaddr=192.168.10.24,mountvers=3,mountport=816,mountproto=tcp,local_lock=none,addr=192.168.10.24)
I redid the tests and as soon as I do a dd with default bs (512B) transfer rates drops to <1Mbit
This is with 8K mount options and I didn’t let it run all the way. A few seconds shows where we are heading.
dd if=/mnt/Serier/CSI/Season\ 01/CSI.Crime.Scene.Investigation.S01E05.Friends.and.Lovers.mkv iflag=direct | pv | dd of=/dev/null
^C96MiB 0:00:06 [ 869KiB/s] [ <=> ]
5657088 bytes (5.7 MB) copied5657088 bytes (5.7 MB) copied, 6.51414 s, 868 kB/s
, 6.51365 s, 868 kB/s
dd if=/mnt/Serier/CSI/Season\ 01/CSI.Crime.Scene.Investigation.S01E05.Friends.and.Lovers.mkv iflag=direct bs=8K | pv | dd of=/dev/null
^C.5MiB 0:00:05 [5.33MiB/s] [ <=> ]
29622272 bytes (30 MB) copied, 5.13737 s, 5.8 MB/s
dd if=/mnt/Serier/CSI/Season\ 01/CSI.Crime.Scene.Investigation.S01E05.Friends.and.Lovers.mkv iflag=direct bs=16K | pv | dd of=/dev/null
^C.9MiB 0:00:09 [7.44MiB/s] [ <=> ]
75923456 bytes (76 MB) copied, 9.89484 s, 7.7 MB/s
