Hi, after the upgrade to buster iptables are no more supported so I try to migrate to nftables.
I try to install them
apt-get install nftables
systemctl enable nftables.service
The service doesn’t work
systemctl status nftables.service
â— nftables.service - nftables
Loaded: loaded (/lib/systemd/system/nftables.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Fri 2020-12-11 16:16:24 CET; 22min ago
Docs: man:nft(8)
http://wiki.nftables.org
Main PID: 338 (code=exited, status=1/FAILURE)
dic 11 16:16:24 vero4k nft[338]: ^^^^^
dic 11 16:16:24 vero4k nft[338]: /etc/nftables.conf:9:15-21: Error: Could not process rule: Operation not supported
dic 11 16:16:24 vero4k nft[338]: chain forward {
dic 11 16:16:24 vero4k nft[338]: ^^^^^^^
dic 11 16:16:24 vero4k nft[338]: /etc/nftables.conf:12:15-20: Error: Could not process rule: Operation not supported
dic 11 16:16:24 vero4k nft[338]: chain output {
dic 11 16:16:24 vero4k systemd[1]: nftables.service: Main process exited, code=exited, status=1/FAILURE
dic 11 16:16:24 vero4k systemd[1]: nftables.service: Failed with result 'exit-code'.
dic 11 16:16:24 vero4k systemd[1]: Failed to start nftables.
If I try with “lsmod | grep nft” I don’t have any result.
I see these posts and it seems to be the same problem:
“Enable nftables support (needs nf_tables* kernel modules) · Issue #198 · Hexxeh/rpi-firmware · GitHub”
“Could nf_tables be enabled in raspbian · Issue #2177 · raspberrypi/linux · GitHub”
$ modinfo nf_tables
modinfo: ERROR: Module nf_tables not found.
Coud this be a kernel problem? Thank you in advance for helping
Best regards
