I’m using the app NHL.tv with my Vero 4k. It seems to just stream the SD version and what i understand it is due to the inputstream adaptive is not active as default in KODI/OSMC. im using the latest version of osmc april 2019.
Activating this i read that i would need to remove the switch resolution to get it streaming on the highest stream possible. Is that correct or did i miss something? I havent tried activating the adaptive yet as i wanted to check if it would affect all the local playing files first. i like that the films represent the correct frame rate (ie resolution switching) and would I like to make the NHL app work at highest resolution as in androidtv it is horrible to watch. I hope i made myself clear.
here is some of the link i read:
https://forum.kodi.tv/showthread.php?tid=243756&page=119
Thanks,
