The night theme for the forum is a bit too white on grey text its almost invisible
Yes - it’s not ideal, but I don’t have enough CSS-fu to fix it.
@TheHacker66 has fixed this for us now. Can you test it?
Seems ok for me, maybe the blue is kinda harsh to the eyes
The new dark mode seems to still be less than ideal…
I run a chrome plug-in that modifies the css when I have it turned on. This is what I see when I use this web site with the standard skin and the plug-in turned on which works quite well.
@darwindesign I’ll revisit the css for the night theme soon to change all the bright colors to their corresponding dark tone. I also tried using a dark mode plugin and while it seems to work quite well it’s obviously better to fine tune the forum’s theme. Will update you when I’ve finished tuning the colors.
