popcornmix, forgive me it was a late night but yes that sounds right. Here, I’ll do it again (i set it all back to the defaults).
Disabled passthrough (have DENON AV receiver).
Enabled Support 8 channel DTS HD audio decoding.
Went to Video, Acceleration. Tried both off, both on, was displeased with the results. (See my last post). The 1st movie i tried was X-Men: Days of future Past - The Rogue Cut. 1920 x 1080 and DTS-HD. Initially with both HW accellerators ON i was pleased with the picture quality, but then i heard this weird guy talking. I tapped the OSD for music settings and saw it was playing track 2, an AC3 director’s commentary track. I tried to change it to the DTS HD MA track but it went silent. There was a 3rd AC3 track but I didn’t try it (figured it was spanish commentary?).
So i looked for another mkv that i 'backed up from my collection of legit Bluray’s and saw that Big Hero 6 had just 1 audio track; a fat DTS-HD MA one and the file was x264 1920 x 1080.
I was SHOCKED that OMXPlayer played the video fine, and when i hit “O” the entire media/codec line was GONE.
So, I disabled the OMXPlayer (which I thought was short for OpenMAX and created FOR the Broadcom chip) and went with the MMAL HW acceleration ONLY.
Like i said it looked and sounded great… it was late and roommates were sleeping, but it seemed to work great. I just woke up and am running late, when i return I will try different ways and see if MMAL is really the best. I would be wise to try it on a mkv that has multiple audio tracks as well, now that i think of it.
As to answer you a bit more clearly–No, there ARE all the options, but it defaulted on X-Men to the AC3 track just played by default, and the DTS-HD track WAS listed but would not play sound. I’ll try now to disable omx & mmal on that x-men file… OOOPS
OK with BOTH omx and mmal ENABLED, X-Men D.o.F.P. Rogue Cut the video is great, but it plays only the director’s commentary track. The OSD shows the DTS HD track but when chosen it stops making sound. The 3rd audio track is also AC3 and it’s the same as the other AC3 track (plays fine too). Sorry i need coffee and shower. Hope that helps.
goober
EDIT: I just now tried to switch the audio to the DTS-HD track on the OSD… and it SAYS it is playing it, but it is still just two dudes talking back and forth. And again, this was with omx AND mmal enabled, passthru disabled, and Support 8 channel enabled. I need coffee.
Cheers,
goober
EDIT #2: So now i tried omx and mmal enabled… video is perfect, AND the DTS-HD track is working, but showing up as “MCH STEREO” on my DENON. It is as if OMX is limiting the amount of channels, because with just mmal enabled the DENON says “MULTI IN” and hits all the satellites (speakers). Gotta run–late for work. Hope that helped.
goober
