No automount after editing the fstab
Hi guys,
I am followed the HOW-TO but it is not working for me.
osmc@osmc:~$ sudo mount -t cifs -o username=kodi,iocharset=utf8,vers=3.0 //192.1 68.1.4/video/Filme/HD /mnt/HD
Password for kodi@//192.168.1.4/video/Filme/HD: ********
osmc@osmc:~$ ls -la /mnt/HD
-rwxr-xr-x 1 root root 17271090935 May 19 23:20 Name des Films.mkv
Entry in the /etc/fstab:
//192.168.1.4/video/Filme/HD /mnt/HD cifs x-systemd.automount,noauto,rw,iocharset=utf8,credentials=/home/osmc/.credentials,uid=osmc,gid=osmc,file_mode=0770,dir_mode=0770,ver=3.0 0 0
I have also tried the following parameters:
nounix
sec=ntlm
with the kodi internal smb client it is working.
command: smbclient -m smb3 -U kodi -L 192.168.1.4
response:
Domain=[SYNOSTATION] OS= Server=
    Sharename       Type      Comment
    homes           Disk      user home
    music           Disk      System default shared folder
    photo           Disk      System default shared folder
    Software        Disk
    video           Disk      System default shared folder
    web             Disk      System default shared folder
    IPC$            IPC       IPC Service ()
    home            Disk      Home directory of kodi
    Server               Comment
    Workgroup            Master
What isn’t working?
with these flags x-systemd.automount,noauto its expected the share won’t automount on startup, only mounts them when you access or the share (or library scan). So are are you not able to access the shares?
Thanks Tom.
@Tom_Doyle
Thanks for the response.
Yes, I am not able to access to the shares.
ls: cannot open directory ‘/mnt/HD’: No such device
is that typo on discourse or fstab, shouldn’t it be vers=3.0?
If that isn’t it, whats the output of:
sudo mount /mnt/HD
Thanks Tom.
P.S I edited your post, to make the fstab entry easier to read.
Hey @Tom_Doyle,
many thanks for our help.
I didn’t put the “s” in it, so it didn’t work.
Now it is working perfectly.
/etc/fstab entry:
//192.168.80.4/video/ /mnt/video cifs x-systemd.automount,noauto,rw,iocharset=utf8,credentials=/home/osmc/.credentials,uid=osmc,gid=osmc,vers=3.0 0 0
I am searched already in the forum for my issue and found only the following thread, but this not resolved my issue:
After every reboot the mountpoint is missing.
osmc@osmc:~$ ls -la /mnt/video/Filme
ls: cannot access ‘/mnt/video/Filme’: No such file or directory
Run the command without an output or error: sudo mount /mnt/video
The access is now possible:
total 0
drwxr-xr-x 2 osmc osmc 0 Aug 16 2019 .
drwxr-xr-x 2 osmc osmc 0 Mar 12 19:56 …
drwxr-xr-x 2 osmc osmc 0 Jun 21 03:43 HD
drwxr-xr-x 2 osmc osmc 0 Jul 3 12:49 UHD
I am have the latest osmc update and the latest DSM update from my synology NAS. I am use SMB3.
here is the log file: https://paste.osmc.tv/axowakofos
Steps to reproduce:
  1. activate the logging and reboot the device 2 times
  2. open a video file like 3 days to kill and the first episode from bates motel
  3. file is not available message is shown
  4. run the command via ssh: sudo mount /mnt/video
  5. open the same file again and the movie is playing now
  6. reboot the device and i need the steps/command again
I don’t found an issue in my fstab.
I tried SMB3 and SMB2, but neither worked.
Have you got wait for network enabled in network settings in MyOSMC?
Looks like a library scan is trying to mount the share, before the network is up.
Thanks Tom.
Sorry for the late response.
Network are connected.
But the file was not found.
After run the following command: sudo mount /mnt/video
The movie starts successfully.
From the photo, it looks like “Wait for Network” is not set. The log also suggest that it is not set.
Yes.
Tick the checkbox “Wait for Network” fixed my problem.
Many thanks for the support.
