hi
Since Dec update my Wdpidrive isn’t automounting. With fdisk -l command device (wdpidrive) appears as expected as /dev/sda1
Has something changed in Dec update regarding support for filesystems - i formatted drive in ext3.
Cheers, Geoff.
hi
Cheers, Geoff.
No, nothing has changed in that regards (other than a timing issue for NFS shares). Provide logs via grab-logs -A
Looks like a drive failure! Is the drive powered by it’s own powersupply?
Try to connect it to your PC to see if it mounts.
Jan 12 20:14:18 11abaro udisks-glue[363]: SG_IO: bad/missing sense data, sb[]: f0 00 01 00 50 40 f0 0a 00 00 00 00 00 1d 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Jan 12 20:14:18 11abaro udisks-glue[363]: /dev/sda: Jan 12 20:14:18 11abaro kernel: EXT2-fs (sda1): error: ext2_check_descriptors: Block bitmap for group 768 not in group (block 631557407)! Jan 12 20:14:18 11abaro kernel: EXT2-fs (sda1): group descriptors corrupted Jan 12 20:14:18 11abaro udisks-glue[363]: Failed to automount /dev/sda1: Error mounting: mount: wrong fs type, bad option, bad superblock on /dev/sda1, Jan 12 20:14:18 11abaro udisks-glue[363]: missing codepage or helper program, or other error Jan 12 20:14:18 11abaro udisks-glue[363]: In some cases useful info is found in syslog - try Jan 12 20:14:18 11abaro udisks-glue[363]: dmesg | tail or so.
thanks for your help, i’ll try your suggestions, cheers, geoff.
