there are strange errors in the logs indicating a problem to work with the device device hdmi:CARD=AMLMESONAUDIO,DEV=0 description AML-MESONAUDIO
2022-05-14 11:59:32.437 T:2758 INFO <general>: CAESinkALSA::EnumerateDevice - device default description
2022-05-14 11:59:32.446 T:2758 INFO <general>: CAESinkALSA - ALSA: confmisc.c:767:(parse_card) cannot find card '$CARD'
2022-05-14 11:59:32.446 T:2758 INFO <general>: CAESinkALSA - ALSA: conf.c:4568:(_snd_config_evaluate) function snd_func_card_driver returned error: No such device
2022-05-14 11:59:32.446 T:2758 INFO <general>: CAESinkALSA - ALSA: confmisc.c:392:(snd_func_concat) error evaluating strings
2022-05-14 11:59:32.446 T:2758 INFO <general>: CAESinkALSA - ALSA: conf.c:4568:(_snd_config_evaluate) function snd_func_concat returned error: No such device
2022-05-14 11:59:32.446 T:2758 INFO <general>: CAESinkALSA - ALSA: confmisc.c:1246:(snd_func_refer) error evaluating name
2022-05-14 11:59:32.446 T:2758 INFO <general>: CAESinkALSA - ALSA: conf.c:4568:(_snd_config_evaluate) function snd_func_refer returned error: No such device
2022-05-14 11:59:32.446 T:2758 INFO <general>: CAESinkALSA - ALSA: conf.c:5047:(snd_config_expand) Evaluate error: No such device
2022-05-14 11:59:32.450 T:2758 INFO <general>: CAESinkALSA - ALSA: conf.c:5014:(snd_config_expand) Unknown parameters CARD=AMLMESONAUDIO,DEV=0
2022-05-14 11:59:32.450 T:2758 INFO <general>: CAESinkALSA - ALSA: conf.c:4898:(parse_args) Unknown parameter DEV
2022-05-14 11:59:32.450 T:2758 INFO <general>: CAESinkALSA - ALSA: conf.c:5031:(snd_config_expand) Parse arguments error: No such file or directory
2022-05-14 11:59:32.451 T:2758 INFO <general>: CAESinkALSA - ALSA: conf.c:4898:(parse_args) Unknown parameter DEV
2022-05-14 11:59:32.451 T:2758 INFO <general>: CAESinkALSA - ALSA: conf.c:5031:(snd_config_expand) Parse arguments error: No such file or directory
2022-05-14 11:59:32.452 T:2758 INFO <general>: CAESinkALSA - ALSA: conf.c:5014:(snd_config_expand) Unknown parameters CARD=AMLMESONAUDIO,DEV=0
2022-05-14 11:59:32.453 T:2758 INFO <general>: CAESinkALSA - ALSA: conf.c:5014:(snd_config_expand) Unknown parameters CARD=AMLMESONAUDIO
2022-05-14 11:59:32.453 T:2758 INFO <general>: CAESinkALSA - ALSA: conf.c:5014:(snd_config_expand) Unknown parameters CARD=AMLMESONAUDIO,DEV=0
2022-05-14 11:59:32.454 T:2758 INFO <general>: CAESinkALSA - ALSA: confmisc.c:1281:(snd_func_refer) Unable to find definition 'cards.AML-MESONAUDIO.pcm.hdmi.1:CARD=AMLMESONAUDIO,AES0=4,AES1=130,AES2=0,AES3=2'
2022-05-14 11:59:32.455 T:2758 INFO <general>: CAESinkALSA - ALSA: conf.c:4568:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
By that the next reachable device AML-MESONAUDIO: HDMI, S/PDIF & analogue is chosen … which is not passthrough capable
2022-05-14 11:59:32.475 T:2758 INFO <general>: CAESinkALSA::EnumerateDevice - device hdmi:CARD=AMLMESONAUDIO,DEV=0 description AML-MESONAUDIO,
HDMI Audio Output
2022-05-14 11:59:32.476 T:2758 DEBUG <general>: CAESinkALSA - Unable to obtain ELD information for device "hdmi:CARD=AMLMESONAUDIO,DEV=0" (not supported by device, or kernel older than 3.2)
2022-05-14 11:59:32.476 T:2758 INFO <general>: CAESinkALSA - ALSA: pcm_hw.c:1216:(snd_pcm_query_chmaps_from_hw) Cannot read Channel Map TLV
2022-05-14 11:59:32.477 T:2758 INFO <general>: Found 1 Lists of Devices
2022-05-14 11:59:32.477 T:2758 INFO <general>: Enumerated ALSA devices:
2022-05-14 11:59:32.477 T:2758 INFO <general>: Device 1
2022-05-14 11:59:32.477 T:2758 INFO <general>: m_deviceName : default
2022-05-14 11:59:32.477 T:2758 INFO <general>: m_displayName : Default (AML-MESONAUDIO: HDMI, S/PDIF & analogue)
2022-05-14 11:59:32.477 T:2758 INFO <general>: m_displayNameExtra:
2022-05-14 11:59:32.477 T:2758 INFO <general>: m_deviceType : AE_DEVTYPE_PCM
2022-05-14 11:59:32.477 T:2758 INFO <general>: m_channels : FL, FR, UNKNOWN1, LFE, FC, BC, BL, BR, BLOC, BROC
2022-05-14 11:59:32.477 T:2758 INFO <general>: m_sampleRates : 32000,44100,48000,64000,88200,96000,176400,192000
2022-05-14 11:59:32.477 T:2758 INFO <general>: m_dataFormats : AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE
2022-05-14 11:59:32.477 T:2758 INFO <general>: m_streamTypes : No passthrough capabilities
Perhaps @grahamh can shed some light here … otherwise I suggest you reinstall the device from scratch.
