No blue LED after reinstallation
I have successfully reinstalled OSMC (from USB).
When I plugin the device to power, I can see red LED (on front) for ~2s.
After this the LED turns off and there’s no blue LED.
Is there any setting to enable blue LED to indicate if device is on/off?
THX
Which model of device do you have?
Can you upload some logs?
My model is: Vero 4K+
Which logs do you need for analysis?
Vero 4K+ does not have a blue LED.
Ah.
That means there’s only red LED in the front that turns on for some seconds after powering on?
Yes, that’s correct.
All right.
This means this issue is closed.
Thanks for your support.
