Hello,
yesterday i update to Kodi 21.1 on my Vero 4+ and where is no Confluence Skin to install and i found no similar Skin to install. Is there a similar Skin availabel for Kodi 21.1 you can recommend for a 71 years old man.
Check out this link
https://forum.kodi.tv/showthread.php?tid=376983
They talk about how you can get it installed again.
Hello,
@vero5
thanks for your quick answer but where comes only not found
Confluence is supported just fine, but you need to update it. See Confluence Skin no longer "compatible" with OSMC latest update (build 21.1.0) (Git 20240824-osmc) · Issue #282 · xbmc/skin.confluence · GitHub
Thanks @sam_nazarko i have forgotten that i can install Skins in Look and Feel but now it works.
I’m also having this issue. I’ve read all the links, which all seem to rely on being able to reinstall Confluence. In one of my OSMC systems, if I navigate
- Add-on browser > left menu > Check for updates
- Add-on browser > Install from repository > Kodi Add-on repository (Version: 9.9.13) > Look and feel
I can see “Skins”, and within that, “Confluence”.
However, on my other system there is no “Skins” category at all. I’ve tried updating and restarting multiple times.
I suggest trying to check for updates again and if you don’t see anything then post some logs.
Thanks @sam_nazarko . I gave it a couple of days, then checked for updates, and the “Skins” category had appeared (including Confluence). Weird, but maybe there was something internal needed to tick over.
The Kodi repository for v21 likely just needed to be updated on your device. This can be triggered manually.
