So, in summary:
activate the logging
reboot the OSMC device
reproduce the issue
upload the log set either using the Log Uploader method within the My OSMC menu in the GUI or the ssh method invoking command grab-logs -A
Can you also confirm when you updated the Denon firmware, please.
The Denon firmware was updated since 1 ou 2 weeks ago.
On the Denon amplifier theres is options to downgrade from an older firmware.
I also try to configure the Denon to use sound from optical cable and not from the hdmi, and the results are identical stereo sound when a dts sound passthrough.
Tomorrow I activate logging on kodi and repeat the operation to have grab-log
Ok It’s my fault I installed pulseaudio. I removed all pulseaudio with apt-get autoremove --purge pulseaudio. On reboot to activate kodi logging all worked perfectly
