OK:
ipconfig didn’t work because the related package doesn’t seem to be installed (and I won’t be able to install it as long as I don’t have internet).
~$ ipconfig
-bash: ipconfig: command not found
~$ route
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
default 192.168.10.2 0.0.0.0 UG 0 0 0 eth0
192.168.10.0 * 255.255.255.0 U 0 0 0 eth0
192.168.10.2 * 255.255.255.255 UH 0 0 0 eth0
~$ sudo cat /etc/resolv.conf
Generated by Connection Manager
nameserver 192.168.10.3
nameserver 192.168.10.2
~$ sudo dmesg
[ 0.000000] Booting Linux on physical CPU 0xf00
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.0-1-osmc (root@vero) (gcc version 4.9.2 (Debian 4.9.2-10) ) #1 SMP PREEMPT Tue Jan 12 17:56:48 UTC 2016
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: Raspberry Pi 2 Model B Rev 1.1
[ 0.000000] cma: Reserved 8 MiB at 0x2e400000
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] On node 0 totalpages: 192512
[ 0.000000] free_area_init_node: node 0, pgdat 80bbd780, node_mem_map add64000
[ 0.000000] Normal zone: 1692 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 192512 pages, LIFO batch:31
[ 0.000000] [bcm2709_smp_init_cpus] enter (9660->f3003010)
[ 0.000000] [bcm2709_smp_init_cpus] ncores=4
[ 0.000000] PERCPU: Embedded 13 pages/cpu @aefac000 s23552 r8192 d21504 u53248
[ 0.000000] pcpu-alloc: s23552 r8192 d21504 u53248 alloc=13*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 190820
[ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2709.boardrev=0xa01041 bcm2709.serial=0x99f223df smsc95xx.macaddr=B8:27:EB:F2:23:DF bcm2708_fb.fbswap=1 bcm2709.uart_clock=3000000 bcm2709.disk_led_gpio=47 bcm2709.disk_led_active_low=0 sdhci-bcm2708.emmc_clock_freq=250000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 root=/dev/mmcblk0p2 rootfstype=ext4 rootwait quiet osmcdev=rbp2
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 741152K/770048K available (7941K kernel code, 436K rwdata, 1860K rodata, 1788K init, 764K bss, 20704K reserved, 8192K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xaf800000 - 0xff800000 (1280 MB)
lowmem : 0x80000000 - 0xaf000000 ( 752 MB)
modules : 0x7f000000 - 0x80000000 ( 16 MB)
.text : 0x80008000 - 0x8099a69c (9802 kB)
.init : 0x8099b000 - 0x80b5a000 (1788 kB)
.data : 0x80b5a000 - 0x80bc7384 ( 437 kB)
.bss : 0x80bca000 - 0x80c8926c ( 765 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000011] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000032] Switching to timer-based delay loop, resolution 52ns
[ 0.000329] Console: colour dummy device 80x30
[ 0.000552] console [tty0] enabled
[ 0.000579] Calibrating delay loop (skipped), value calculated using timer frequency… 38.40 BogoMIPS (lpj=192000)
[ 0.000608] pid_max: default: 32768 minimum: 301
[ 0.000964] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000986] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.002204] Disabling cpuset control group subsystem
[ 0.002254] Initializing cgroup subsys io
[ 0.002287] Initializing cgroup subsys memory
[ 0.002339] Initializing cgroup subsys devices
[ 0.002365] Initializing cgroup subsys freezer
[ 0.002388] Initializing cgroup subsys net_cls
[ 0.002458] CPU: Testing write buffer coherency: ok
[ 0.002539] ftrace: allocating 19374 entries in 57 pages
[ 0.049694] CPU0: update cpu_capacity 1024
[ 0.049736] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[ 0.049752] [bcm2709_smp_prepare_cpus] enter
[ 0.049896] Setting up static identity map for 0x8240 - 0x8298
[ 0.129310] [bcm2709_boot_secondary] cpu:1 started (0) 16
[ 0.129661] [bcm2709_secondary_init] enter cpu:1
[ 0.129723] CPU1: update cpu_capacity 1024
[ 0.129732] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[ 0.159338] [bcm2709_boot_secondary] cpu:2 started (0) 18
[ 0.159617] [bcm2709_secondary_init] enter cpu:2
[ 0.159652] CPU2: update cpu_capacity 1024
[ 0.159660] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[ 0.189414] [bcm2709_boot_secondary] cpu:3 started (0) 18
[ 0.189666] [bcm2709_secondary_init] enter cpu:3
[ 0.189698] CPU3: update cpu_capacity 1024
[ 0.189706] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[ 0.189799] Brought up 4 CPUs
[ 0.189830] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.189841] CPU: All CPU(s) started in HYP mode.
[ 0.189849] CPU: Virtualization extensions available.
[ 0.190730] devtmpfs: initialized
[ 0.201641] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.202120] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.203174] pinctrl core: initialized pinctrl subsystem
[ 0.203992] NET: Registered protocol family 16
[ 0.209476] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.239552] cpuidle: using governor ladder
[ 0.269583] cpuidle: using governor menu
[ 0.276487] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.276506] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.276689] Serial: AMBA PL011 UART driver
[ 0.276995] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
[ 0.277685] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.351262] bcm2835-dma 3f007000.dma: DMA legacy API manager at f3007000, dmachans=0x1
[ 0.353207] SCSI subsystem initialized
[ 0.353440] usbcore: registered new interface driver usbfs
[ 0.353563] usbcore: registered new interface driver hub
[ 0.353726] usbcore: registered new device driver usb
[ 0.359807] raspberrypi-firmware soc:firmware: Attached to firmware from 2016-02-01 17:54
[ 0.386993] clocksource: Switched to clocksource arch_sys_counter
[ 0.439223] FS-Cache: Loaded
[ 0.439673] CacheFiles: Loaded
[ 0.456184] NET: Registered protocol family 2
[ 0.457478] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.457617] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.457811] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.457942] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.458008] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.458361] NET: Registered protocol family 1
[ 0.458873] RPC: Registered named UNIX socket transport module.
[ 0.458891] RPC: Registered udp transport module.
[ 0.458902] RPC: Registered tcp transport module.
[ 0.458913] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.572199] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[ 0.574781] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.574971] audit: initializing netlink subsys (disabled)
[ 0.575048] audit: type=2000 audit(0.539:1): initialized
[ 0.590569] VFS: Disk quotas dquot_6.6.0
[ 0.590969] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.593749] FS-Cache: Netfs ‘nfs’ registered for caching
[ 0.594889] NFS: Registering the id_resolver key type
[ 0.594961] Key type id_resolver registered
[ 0.594974] Key type id_legacy registered
[ 0.598570] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 0.598781] io scheduler noop registered
[ 0.599342] io scheduler bfq registered (default)
[ 0.599355] BFQ I/O-scheduler version: v7r7
[ 0.602105] BCM2708FB: allocated DMA memory ee800000
[ 0.602154] BCM2708FB: allocated DMA channel 0 @ f3007000
[ 0.636374] Console: switching to colour frame buffer device 240x67
[ 1.605239] bcm2835-rng 3f104000.rng: hwrng registered
[ 1.605401] vc-cma: Videocore CMA driver
[ 1.605416] vc-cma: vc_cma_base = 0x00000000
[ 1.605428] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 1.605439] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 1.605759] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[ 1.626637] brd: module loaded
[ 1.637958] loop: module loaded
[ 1.639079] vchiq: vchiq_init_state: slot_zero = 0xae880000, is_master = 0
[ 1.640886] Loading iSCSI transport class v2.0-870.
[ 1.641776] usbcore: registered new interface driver smsc95xx
[ 1.641859] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.842265] Core Release: 2.80a
[ 1.842287] Setting default values for core params
[ 1.842312] Finished setting default values for core params
[ 2.042733] Using Buffer DMA mode
[ 2.042751] Periodic Transfer Interrupt Enhancement - disabled
[ 2.042761] Multiprocessor Interrupt Enhancement - disabled
[ 2.042773] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 2.042791] Dedicated Tx FIFOs mode
[ 2.043206] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xae814000 dma = 0xee814000 len=9024
[ 2.043248] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
[ 2.043275] dwc_otg: Microframe scheduler enabled
[ 2.043347] WARN::hcd_init_fiq:413: FIQ on core 1 at 0x80570454
[ 2.043366] WARN::hcd_init_fiq:414: FIQ ASM at 0x805707c4 length 36
[ 2.043386] WARN::hcd_init_fiq:439: MPHI regs_base at 0xaf87e000
[ 2.043475] dwc_otg 3f980000.usb: DWC OTG Controller
[ 2.043550] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 2.043609] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[ 2.043663] Init: Port Power? op_state=1
[ 2.043674] Init: Power Port (0)
[ 2.044012] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.044034] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.044051] usb usb1: Product: DWC OTG Controller
[ 2.044067] usb usb1: Manufacturer: Linux 4.4.0-1-osmc dwc_otg_hcd
[ 2.044083] usb usb1: SerialNumber: 3f980000.usb
[ 2.045242] hub 1-0:1.0: USB hub found
[ 2.045317] hub 1-0:1.0: 1 port detected
[ 2.046123] dwc_otg: FIQ enabled
[ 2.046138] dwc_otg: NAK holdoff enabled
[ 2.046149] dwc_otg: FIQ split-transaction FSM enabled
[ 2.046192] Module dwc_common_port init
[ 2.046601] usbcore: registered new interface driver usb-storage
[ 2.047022] mousedev: PS/2 mouse device common for all mice
[ 2.047648] usbcore: registered new interface driver usbtouchscreen
[ 2.047991] bcm2835-cpufreq: min=600000 max=900000
[ 2.050599] sdhci: Secure Digital Host Controller Interface driver
[ 2.050609] sdhci: Copyright(c) Pierre Ossman
[ 2.050977] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[ 2.050992] mmc-bcm2835 3f300000.mmc: DMA channels allocated
[ 2.087116] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.087639] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.087790] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.087991] usbcore: registered new interface driver usbhid
[ 2.087999] usbhid: USB HID core driver
[ 2.088397] Initializing XFRM netlink socket
[ 2.088434] NET: Registered protocol family 17
[ 2.088583] Key type dns_resolver registered
[ 2.088726] Registering SWP/SWPB emulation handler
[ 2.089542] registered taskstats version 1
[ 2.089725] vc-sm: Videocore shared memory driver
[ 2.089739] [vc_sm_connected_init]: start
[ 2.090328] [vc_sm_connected_init]: end - returning 0
[ 2.093304] Freeing unused kernel memory: 1788K (8099b000 - 80b5a000)
[ 2.124687] mmc0: host does not support reading read-only switch, assuming write-enable
[ 2.126869] mmc0: new high speed SDHC card at address 0007
[ 2.127677] mmcblk0: mmc0:0007 SL16G 14.4 GiB
[ 2.129061] mmcblk0: p1 p2
[ 2.237227] Indeed it is in host mode hprt0 = 00021501
[ 2.417049] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.417210] Indeed it is in host mode hprt0 = 00001101
[ 2.617469] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 2.617494] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.618668] hub 1-1:1.0: USB hub found
[ 2.618794] hub 1-1:1.0: 5 ports detected
[ 2.897019] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 2.997267] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 2.997283] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.000387] smsc95xx v1.0.4
[ 3.060268] smsc95xx 1-1.1:1.0 eth0: register ‘smsc95xx’ at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:f2:23:df
[ 14.088371] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 14.099029] fsck: E2fsck run: /bin/e2fsck -p -C 0 /dev/mmcblk0p2
[ 14.099268] fsck: Filesystem UUID: 781b65e0-1156-4423-8249-84dc1c8baed0
[ 14.099482] fsck: Filesystem UUID: 781b65e0-1156-4423-8249-84dc1c8baed0
[ 14.099682] fsck: Setting free inodes count to 191301 (was 191326)
[ 14.099879] fsck: Setting free blocks count to 655482 (was 655640)
[ 14.100120] fsck: /dev/mmcblk0p2: clean, 35387/226688 files, 249734/905216 blocks
[ 15.653942] random: systemd urandom read with 97 bits of entropy available
[ 15.710622] NET: Registered protocol family 10
[ 16.069041] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.
[ 16.069258] systemd[1]: Found ordering cycle on basic.target/start
[ 16.069280] systemd[1]: Found dependency on sysinit.target/start
[ 16.069300] systemd[1]: Found dependency on rpcbind.service/start
[ 16.069318] systemd[1]: Found dependency on network-online.target/start
[ 16.069336] systemd[1]: Found dependency on connman-wait-for-network.service/start
[ 16.069355] systemd[1]: Found dependency on basic.target/start
[ 16.069373] systemd[1]: Breaking ordering cycle by deleting job rpcbind.service/start
[ 16.069393] systemd[1]: Job rpcbind.service/start deleted to break ordering cycle starting with basic.target/start
[ 16.069662] systemd[1]: Found ordering cycle on basic.target/start
[ 16.069686] systemd[1]: Found dependency on sysinit.target/start
[ 16.069705] systemd[1]: Found dependency on kbd.service/start
[ 16.069724] systemd[1]: Found dependency on remote-fs.target/start
[ 16.069741] systemd[1]: Found dependency on remote-fs-pre.target/start
[ 16.069759] systemd[1]: Found dependency on connman.service/start
[ 16.069775] systemd[1]: Found dependency on basic.target/start
[ 16.069793] systemd[1]: Breaking ordering cycle by deleting job kbd.service/start
[ 16.069813] systemd[1]: Job kbd.service/start deleted to break ordering cycle starting with basic.target/start
[ 16.297139] fuse init (API version 7.23)
[ 16.365986] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 16.623706] systemd-udevd[187]: starting version 215
[ 16.835572] lirc_dev: IR Remote Control driver registered, major 245
[ 16.841934] lirc_rpi: module is from the staging directory, the quality is unknown, you have been warned.
[ 16.961869] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[ 16.963872] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 17.241084] random: nonblocking pool is initialized
[ 17.242049] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 17.797084] lirc_rpi: auto-detected active high receiver on GPIO pin 18
[ 17.797464] platform lirc_rpi: lirc_dev: driver lirc_rpi registered at minor = 0
[ 17.797480] lirc_rpi: driver registered!
[ 17.993724] systemd-journald[164]: Received request to flush runtime journal from PID 1
[ 18.173500] input: lircd as /devices/virtual/input/input0
[ 18.454033] smsc95xx 1-1.1:1.0 eth0: hardware isn’t capable of remote wakeup
[ 18.454314] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 20.065138] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 20.070890] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
[ 20.087542] 8021q: 802.1Q VLAN Support v1.8
[ 28.513886] Console: switching to colour dummy device 80x30
Since that issue happens only with OSMC installs obviously and just since a couple days, even with images I back-upped months before which always worked, do you think my internet provider might have screwed something here?
