I have an odd behaviour with OSMC with Kodi 19.1 on my rpi3.
Right after booting up, sound is working fine. Kodi menu click sounds are there, I can stream and hear music via raspotify and I can start movies and audio with passthrough is working just fine.
But once I started a movie playback and then stop/end the playback, there is no more sound… no menu click sounds, I can no longer hear music streamed via raspotify. If I start another movie, audio is working fine again, with passthrough. But when I stop it again, no audio…
What I tried:
in the settings → system → audio menu changing eg the feature “keep audio device active” restores audio directly, right afterwards click sounds are back, raspotify playback works (but just until next movie playback ends). I tried off, 1min, 2min, always
settings → system → audio → enable/disable output inaudible signal makes no difference
as I read something regarding joystick and controller support interfering with this audio stuff, I deactivated drivers and peripherals for joystick, mouse and controllers, but with no effect
Any further ideas? It is not that I couldnt live without those click sounds, but also other audio output (except movie playback) doesnt work. So would make sense to get this fixed
It is a fresh Kodi 19.1 on OSMC install, my old OSMC with latest Kodi 18 works normal without this bug. It is the same hardware, just a new SD card.
reproduce the issue
entering menu settings → system → audio and toggled Output inaudible audio signal (Unhörbares Uadio Signal ausgeben) to re-enable audio and sounds
stopped debug logging
As I wrote in first post, if I start another movie playback, I get normal sound from movie, but afterwards still no sounds on the menu or elsewhere
Unfortunately there are no readable audio capabilities of the connected HDMI device in the logs but the first thing I suggest to change is to set GUI → settings → system → audio → output configuration → best match instead of optimized.
When I press the return button on my remote while playing a videofile I dont get any menu sounds either. Not until I actually press the stop button. That might help you too.
While playback is running no menu sounds are played,I set that in the audio settings, actually it is also default. But my problem arises onve I stop the playback, so not pause, but really stop the playback and close the movie.
Still existent on my RPi3… but I just tried it with a new RPi4 and Kodi 19.1 on OSMC and with my old kodi installation from RPI3 and issue doesnt appear on RPi4…
