I suspect I may have some kind of file system error going on (I have had some power main losses to the house).
== The issue you are currently experiencing with OSMC
Certain add-ons (Bandcamp, Crackle) and my screensavers (Kaster) no longer work. The add-ons error out and tell me to check the log. Kaster no longer activates even from the Preview option in the screensaver menu. Content from the NAS plays fine.
== What you were doing when this issue occurred
I replicated the error by first enabling debugging and rebooting twice, and then tried to get the add-ons to pull content. Both start and I can successfully click in one level. For example, in Bandcamp I get to the initial screen that has Discover, Search, etc. but selecting anything from this page errors out with the debug message. I can, however, successfully start the Soma.fm add-on and play content.
== The device you are currently running OSMC on
Running a Vero 4K + (since ~2022) connected via ethernet . Previously, I was running on Pi 3b.
== What peripherals are attached to the device?
I have a NAS (also wired ethernet) and PiHole (two instances, one on my old Pi 3b and one on the NAS via Docker). Vero connected to Yamaha receiver, which is in turn connected to a Samsung TV.
== Has this issue been introduced by a new version of OSMC? When did the issue first appear and can you recall a time when it was not present?
I do not believe my issues have anything to do with OSMC upgrades. I have had issues with my screen saver (Kaster) for ~6 months. The add-ons started within the past week.
== Log available here:
https://paste.osmc.tv/ewerodudup
After the two reboots, I tried: (1) Bandcamp (failed), (2) Crackle (failed) , and then (3) Soma.fm (worked).
I will be traveling this week and am likely to be slow to respond to questions.
Thanks for the help and I really love the OSMC platform!
Paul
