No Manual Network Config Option
I did a fresh install on my RP 3, and used incorrect network settings. The install completed and now I cannot correct the settings for either wifi or wired. ‘Configure Network Manually’ option is not displayed and each time I try to override the settings they revert back to the incorrect settings. Any help would be appreciated.
The quickest way would be a reinstall.
Otherwise some logs, and confirmation of which version of OSMC you installed would be useful
Thanks Sam, I figured it’d be a re-install. It’s the latest version of OSMC.
For you, what version is that?
2023.07-01
Reinstall fixed everything, thanks.
