Hello,
i hope you Guys can help my, i tried so many things and Settings now, i don’t know what to do anymore. First my Problem: i installed OSMC on a Raspberry Pi 4 and running it trough a (brand new) 7.5m HDMI Cable to my Yamaha AV RX-V379 Receiver. As TV i use a Sony Bravia KDX8008C UHD. The Firmware on all Devices are updated, i use the newest Version of OSMC. Everything is just working fine, i can play Movies, watch IP TV, can watch Music Videos etc etc. But after some time, the whole Audio drops out. It seems to be complete randomly. Sometime it happens after i stop a running Video, sometimes when i leave the Main Menue for a few Minutes and do nothing. But when i then click through the Items, i hear no more Sound. When i start a Movie, no more Sound. For the first 10 Seconds the Video freezes, then continue but whith no Sound. There is no way i can change, to get the Sound back. The only Solution is to restart the whole Raspberry. Then everything is workin fine again till the next dropout.
I tried Libreelec on another SD Card and there i have no Problems, everything seems to work fine. But i want to stick with OSMC, because i run a Home Assistant Supervisor Installation on the same Device. I used this Combination for about 1 1/2 Years, everything worked fine, no Audio dropouts untill my SSD died on the Pi running the OSMC/Home Assistant. I wasn’t able to recover the HDD Data, so i installed a new SSD and reinstalled a fresh Version of OSMC/Home Assistant. But since then i have this Problems.
I tried to change all Settings, change the Channels from 5.1 to 2.0, changed the Output Device, changed the Keep alive Signal from 1 Minute to Infinite and back… enabled and disabled the Passthrough. Nothing helps.
So i hope someone can help me figure out the Problem here.
Here are my uploaded Log Files: https://paste.osmc.tv/motupohabo.xml
I think the Point where it happes is right at the End of the log:
2022-12-19 14:24:21.713 T:848 INFO : CActiveAESink::OpenSink - initialize sink
2022-12-19 14:24:21.713 T:848 DEBUG : CActiveAESink::OpenSink - trying to open device ALSA:sysdefault:CARD=vc4hdmi0
2022-12-19 14:24:21.714 T:848 INFO : CAESinkALSA::Initialize - Attempting to open device “sysdefault:CARD=vc4hdmi0”
2022-12-19 14:24:21.720 T:848 INFO : CAESinkALSA - ALSA: pcm_hw.c:1715:(snd_pcm_hw_open) open ‘/dev/snd/pcmC0D0p’ failed (-16): Device or resource busy
2022-12-19 14:24:21.720 T:848 INFO : CAESinkALSA - Unable to open device “sysdefault:CARD=vc4hdmi0” for playback
2022-12-19 14:24:21.720 T:848 ERROR : CAESinkALSA::Initialize - failed to initialize device “sysdefault:CARD=vc4hdmi0”
2022-12-19 14:24:21.721 T:848 DEBUG : CActiveAESink::OpenSink - trying to open device ALSA:default
2022-12-19 14:24:21.721 T:848 INFO : CAESinkALSA::Initialize - Attempting to open device “default”
2022-12-19 14:24:21.726 T:848 INFO : CAESinkALSA - ALSA: pcm_hw.c:1715:(snd_pcm_hw_open) open ‘/dev/snd/pcmC0D0p’ failed (-16): Device or resource busy
2022-12-19 14:24:21.726 T:848 INFO : CAESinkALSA - Unable to open device “default” for playback
2022-12-19 14:24:21.726 T:848 ERROR : CAESinkALSA::Initialize - failed to initialize device “default”
2022-12-19 14:24:21.727 T:848 ERROR : CActiveAESink::OpenSink - no sink was returned
This Error-Message repeats and repeats and spam the Log File. But what is causing this??
Thank you very much for any Help!
Greetings from Germany
