Hi - just installed latest version, & I can’t access any of my Windows 10 folders (SMB), using wired ethernet. Trying to browse, all show either connection timed out or invalid.
Any clues please?
Any clues please?
Hard to say with no relevant details or logs…
reproduce the issue
Is it only smb://Acer-mb with the issue? Do the sources using IP addresses still work? If so I would check and see if you can connect to that source if you use an IP address and if so I would just add a path substitution to swap the name for the number.
unfortunately both are failing, ie IP or name.
Is Acer-mb and 192.168.1.99 the same Win10 PC? Was this something you setup using SMBv1 (ie guest access, no password)? Have you tried ssh’ing into your Vero and doing a ping back to this PC?
yes, same machine. No, can you explain how I do the SSH into the Vero, & I could try that?
More complete instructions [here] but short form for you assuming you didn’t disable ssh during first boot and are using default passwords would be to click on the start menu in Windows, type in “cmd” and hit enter, then type in…
ssh osmc@192.168.1.135
and then enter the password “osmc” and assuming it dropped you into the terminal and you typed yes and enter for the security question you would then type…
ping 192.168.1.99
It should start dropping lines for a bunch of responses without errors about not being able to find the network location. You can ctrl+c to stop ping and exit to close the terminal session and return to cmd.
Hi - thanks for this. I found that I wasn’t seeing the network folders on a laptop either. I changed the SMB client setting to ON in Windows features, & rebooted the PC.
All seems ok now, so hopefully that was root cause (although don’t understand how it could have changed).
thanks for your help, at least now I know how to raise a problem & post a log file.
