Hi there
I just installed a fresh OSMC on a Pi3. When I want to connect to a share on my Windows PC, there is no option to Add Network Location or any other locations besides the folders on the Pi.
Did I do the install incorrectly?
Hi there
If you go Video, files, add videos … and then browse. Can you please list the locations you see?
Thanks Tom.
Hi Tom
In Browse it says “”. This is for Video, Audio and everything.
I can ping to the Internet, eg 8.8.8.8
Hi Tom
Ok, I plugged it into an ethernet switch and now I can see a lot more. Will try this and see how it goes.
Thank you.
