Unfortunate given the millions out there and the 1$ price tag…
But thanks… appreciated…
I will do my best but can’t promise anything.
For now you could downgrade your kernel with minimal impact.
unfortunately I have no idea how to do that
I’m not sure why you are using an experimental (staging) repository then.
You can use apt-cache search rbp2-image to find the last kernel and install it.
Ahh the things user can do
I’ll give that a go…
thanks
hmm looked at that and can see the previous image but have no idea where to go from there…
I’ll keep using my BT keyboard and wait for the FLIRC I ordered to arrive…
Thanks again
I am struggling with the same exact issue with my go to remote, Rii with dongle and Yatse (android phone). I don’t use Yatse often at all but tried it to assure this is not a remote control issue and It doesn’t function anymore either. After this last update first few reboots got onscreen error’s stating remote server failed to start. If I reboot a few times and move the Rii dongle to other USB port I can get it and the Yatse working again but there is defiantly a bug in the last update. That said this is my first issue ever using the vero4k+ after 8 or so months of use, otherwise very happy.
Doesn’t sound like the same issue if you are having problems using a smartphone. Logs under a new post would be the best idea
