Hello
I was planning to copy a large set of files on to a HD attached to Vero 4K+ using Rsync. But the debian build doesn’t have Rsync to install using
sudo apt-get install rysnc
Hello
Rsync is already installed on OSMC
osmc@osmc-vero4k:~$ which rsync /usr/bin/rsync
osmc@osmc-vero4k:~$ dpkg -l | grep rsync ii rsync 3.1.3-6 armhf fast, versatile, remote (and local) file-copying tool
Ah, ok.
Though when I type
rysnc --version
get:
-bash: rsync: command not found
Which is same error when I try to rynsc into osmc from my PC
(I’m still learning linux so probably a dumb error on my part)
Where did you type that?
Did you connect to the Vero via SSH?
Or are you typing that on your local machine? Which OS?
Yes, ssh into vero (from a MX Linux PC).
And when I use the which and dpkg commands, no output appears
osmc@osmc-ss:~$ rsync --version
osmc@osmc-ss:~$ which rsync
osmc@osmc-ss:~$ dpkg -l | grep rsync
osmc@osmc-ss:~$
can you post the output of
sudo apt-get update
sudo apt-get install rsync
osmc@osmc-ss:~$ sudo apt-get update
Hit:1 http://security.debian.org buster/updates InRelease
Hit:2 http://ftp.debian.org/debian buster InRelease
Get:3 http://ftp.debian.org/debian buster-updates InRelease [51.9 kB]
Hit:4 http://ftp.fau.de/osmc/osmc/apt buster InRelease
Fetched 51.9 kB in 2s (28.8 kB/s)
Reading package lists... Done
osmc@osmc-ss:~$ sudo apt-get install rysnc
Building dependency tree
E: Unable to locate package rysnc
osmc@osmc-ss:~$
Rsync is not installed on my vero4k, which was last installed in March 2018, but is installed on my Pi3, which was last installed in October 2020.
Typo. It’s rsync.
Argh, what a dunderhead
Installs fine and works fine. Thanks!
And sorry for taking up your time.
