pi screen attached and red AV cable to yellow input
state 0x400000 [LCD], 800x480 @ 60.00Hz, progressive
log file
08:30:35.165 T:1958323120 NOTICE: special://profile/ is mapped to: special://masterprofile/
08:30:35.165 T:1958323120 NOTICE: -----------------------------------------------------------------------
08:30:35.165 T:1958323120 NOTICE: Starting Kodi (17.1). Platform: Linux ARM (Thumb) 32-bit
08:30:35.165 T:1958323120 NOTICE: Using Release Kodi x32 build (version for Raspberry Pi)
08:30:35.165 T:1958323120 NOTICE: Kodi compiled Mar 22 2017 by GCC 4.9.2 for Linux ARM (Thumb) 32-bit version 3.16.39 (200743)
08:30:35.165 T:1958323120 NOTICE: Running on Open Source Media Center 2017.03-1, kernel: Linux ARM 32-bit version 4.4.27-9-osmc
08:30:35.172 T:1958323120 NOTICE: FFmpeg version/source: ffmpeg-3.1-kodi
08:30:35.172 T:1958323120 NOTICE: Host CPU: ARMv7 Processor rev 4 (v7l), 4 cores available
08:30:35.172 T:1958323120 NOTICE: ARM Features: Neon disabled
08:30:35.172 T:1958323120 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
08:30:35.172 T:1958323120 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
08:30:35.172 T:1958323120 NOTICE: special://xbmcbinaddons/ is mapped to: /usr/lib/kodi/addons
08:30:35.172 T:1958323120 NOTICE: special://masterprofile/ is mapped to: /home/osmc/.kodi/userdata
08:30:35.172 T:1958323120 NOTICE: special://envhome/ is mapped to: /home/osmc
08:30:35.172 T:1958323120 NOTICE: special://home/ is mapped to: /home/osmc/.kodi
08:30:35.172 T:1958323120 NOTICE: special://temp/ is mapped to: /home/osmc/.kodi/temp
08:30:35.172 T:1958323120 NOTICE: special://logpath/ is mapped to: /home/osmc/.kodi/temp
08:30:35.172 T:1958323120 NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
08:30:35.172 T:1958323120 NOTICE: Local hostname: MobilePi
08:30:35.172 T:1958323120 NOTICE: Log File is located: /home/osmc/.kodi/temp//kodi.log
08:30:35.173 T:1958323120 NOTICE: -----------------------------------------------------------------------
08:30:35.254 T:1958323120 ERROR: DBus: Error org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
08:30:35.363 T:1958323120 NOTICE: load settings…
08:30:35.531 T:1958323120 NOTICE: Found 2 Lists of Devices
08:30:35.531 T:1958323120 NOTICE: Enumerated PI devices:
08:30:35.531 T:1958323120 NOTICE: Device 1
08:30:35.531 T:1958323120 NOTICE: m_deviceName : HDMI
08:30:35.531 T:1958323120 NOTICE: m_displayName : HDMI
08:30:35.531 T:1958323120 NOTICE: m_displayNameExtra:
08:30:35.531 T:1958323120 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
08:30:35.531 T:1958323120 NOTICE: m_channels : FL,FR
08:30:35.531 T:1958323120 NOTICE: m_sampleRates : 8000,11025,16000,22050,24000,32000,44100,48000,88200,96000,176400,192000
08:30:35.531 T:1958323120 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP,AE_FMT_RAW
08:30:35.531 T:1958323120 NOTICE: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_EAC3,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_512
08:30:35.531 T:1958323120 NOTICE: Device 2
08:30:35.531 T:1958323120 NOTICE: m_deviceName : Analogue
08:30:35.531 T:1958323120 NOTICE: m_displayName : Analogue
08:30:35.531 T:1958323120 NOTICE: m_deviceType : AE_DEVTYPE_PCM
08:30:35.532 T:1958323120 NOTICE: m_channels : FL,FR
08:30:35.532 T:1958323120 NOTICE: m_sampleRates : 48000
08:30:35.532 T:1958323120 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP
08:30:35.532 T:1958323120 NOTICE: m_streamTypes : No passthrough capabilities
08:30:35.532 T:1958323120 NOTICE: Device 3
08:30:35.532 T:1958323120 NOTICE: m_deviceName : Both
08:30:35.532 T:1958323120 NOTICE: m_displayName : HDMI and Analogue
08:30:35.532 T:1958323120 NOTICE: m_displayNameExtra:
08:30:35.532 T:1958323120 NOTICE: m_deviceType : AE_DEVTYPE_PCM
08:30:35.532 T:1958323120 NOTICE: Enumerated ALSA devices:
08:30:35.532 T:1958323120 NOTICE: Device 1
08:30:35.532 T:1958323120 NOTICE: m_deviceName : @
08:30:35.532 T:1958323120 NOTICE: m_displayName : Default (bcm2835 ALSA bcm2835 ALSA)
08:30:35.532 T:1958323120 NOTICE: m_sampleRates : 8000,11025,16000,22050,32000,44100,48000
08:30:35.532 T:1958323120 NOTICE: m_dataFormats : AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_U8
08:30:35.542 T:1958323120 ERROR: CSettings: unable to load settings from special://masterprofile/guisettings.xml, creating new default settings
08:30:35.651 T:1958323120 NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
08:30:35.652 T:1958323120 NOTICE: Contents of special://xbmc/system/advancedsettings.xml are…
<?xml version="1.0" encoding="UTF-8" ?>
540
720
false
0
30
08:30:35.653 T:1958323120 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
08:30:35.653 T:1958323120 NOTICE: Default Video Player: VideoPlayer
08:30:35.653 T:1958323120 NOTICE: Default Audio Player: paplayer
08:30:35.653 T:1958323120 NOTICE: Disabled debug logging due to GUI setting. Level 0.
08:30:35.653 T:1958323120 NOTICE: Log level changed to “LOG_LEVEL_NORMAL”
08:30:35.664 T:1958323120 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
08:30:35.668 T:1958323120 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
08:30:35.672 T:1958323120 NOTICE: Loaded playercorefactory configuration
08:30:35.673 T:1958323120 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
08:30:35.673 T:1958323120 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
08:30:36.186 T:1958323120 NOTICE: Running database version Addons27
08:30:37.578 T:1958323120 NOTICE: ADDONS: Using repository repository.xbmc.org
08:30:37.578 T:1958323120 NOTICE: ADDONS: Using repository repository.alanon
08:30:37.578 T:1958323120 NOTICE: ADDONS: Using repository repository.marcelveldt
08:30:37.578 T:1958323120 NOTICE: ADDONS: Using repository repository.dandymedia
08:30:37.578 T:1958323120 NOTICE: ADDONS: Using repository repository.metalkettle
08:30:37.578 T:1958323120 NOTICE: ADDONS: Using repository repository.filmkodi.com
08:30:37.578 T:1958323120 NOTICE: ADDONS: Using repository repository.noobsandnerds
08:30:37.578 T:1958323120 NOTICE: ADDONS: Using repository repository.exodus
08:30:37.578 T:1958323120 NOTICE: ADDONS: Using repository repository.xbmchub
08:30:37.578 T:1958323120 NOTICE: ADDONS: Using repository repository.GearsTV
08:30:37.578 T:1958323120 NOTICE: ADDONS: Using repository repository.tknorris.release
08:30:37.578 T:1958323120 NOTICE: ADDONS: Using repository repository.istream
08:30:37.578 T:1958323120 NOTICE: ADDONS: Using repository repository.q
08:30:37.578 T:1958323120 NOTICE: ADDONS: Using repository repository.wolfpack
08:30:37.578 T:1958323120 NOTICE: ADDONS: Using repository repository.origin
08:30:37.578 T:1958323120 NOTICE: ADDONS: Using repository repository.arnubox
08:30:37.765 T:1958323120 NOTICE: Raspberry PI firmware version: Mar 3 2017 13:47:28
Copyright (c) 2012 Broadcom
version 9ae30f71c7ef4239e9d5b56346c0842f3ef56736 (clean) (release)
08:30:37.765 T:1958323120 NOTICE: ARM mem: 752MB GPU mem: 256MB MPG2:0 WVC1:0
08:30:37.765 T:1958323120 NOTICE: cache.memorysize: 20MB libass.cache: 0MB
08:30:37.765 T:1958323120 NOTICE: Config:
arm_freq=1200
audio_pwm_mode=1
config_hdmi_boost=5
core_freq=400
desired_osc_freq=0x36ee80
disable_commandline_tags=2
disable_l2cache=1
disable_splash=1
display_default_lcd=1
force_eeprom_read=1
force_pwm_open=1
framebuffer_ignore_alpha=1
framebuffer_swap=1
gpu_freq=300
hdmi_channel_map=8
hdmi_force_cec_address=65535
hdmi_ignore_cec_init=1
init_uart_clock=0x2dc6c00
lcd_framerate=60
over_voltage_avs=37500
over_voltage_avs_boost=37500
overscan_scale=1
pause_burst_frames=1
program_serial_random=1
sdram_freq=450
temp_limit=85
08:30:37.766 T:1958323120 NOTICE: Config:
device_tree=-
08:30:37.774 T:1958323120 NOTICE: InitWindowSystem: Using EGL Implementation: raspberrypi
08:30:37.775 T:1958323120 NOTICE: Found resolution 800 x 480 for display 0 with 800 x 480 @ 60.000000 Hz
08:30:37.775 T:1958323120 NOTICE: Found (800x480@60.000000) at 16, setting to RES_DESKTOP at 16
08:30:37.775 T:1958323120 NOTICE: Checking resolution 16
08:30:37.937 T:1958323120 NOTICE: GL_VENDOR = Broadcom
08:30:37.937 T:1958323120 NOTICE: GL_RENDERER = VideoCore IV HW
08:30:37.937 T:1958323120 NOTICE: GL_VERSION = OpenGL ES 2.0
08:30:37.938 T:1958323120 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
08:30:37.938 T:1958323120 NOTICE: GL_EXTENSIONS = GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture GL_OES_texture_npot GL_OES_depth24 GL_OES_vertex_half_float GL_OES_EGL_image GL_OES_EGL_image_external GL_EXT_discard_framebuffer GL_OES_rgb8_rgba8 GL_OES_depth32 GL_OES_mapbuffer GL_EXT_texture_format_BGRA8888 GL_APPLE_rgb_422 GL_EXT_debug_marker
08:30:39.551 T:1830274032 NOTICE: Register - new cec device registered on cec->RPI: CEC Adapter (2708:1001)
08:30:39.594 T:1937765360 NOTICE: Running database version Addons27
08:30:39.600 T:1937765360 NOTICE: Running database version ViewModes6
08:30:39.605 T:1937765360 NOTICE: Running database version Textures13
08:30:39.624 T:1937765360 NOTICE: Running database version MyMusic60
08:30:39.640 T:1937765360 NOTICE: Running database version MyVideos107
08:30:39.649 T:1937765360 NOTICE: Running database version TV29
08:30:39.653 T:1937765360 NOTICE: Running database version Epg11
08:30:39.657 T:1958323120 NOTICE: start dvd mediatype detection
08:30:40.230 T:1958323120 WARNING: Label Formating: $VAR[widgetBackground] is not defined
08:30:40.557 T:1958323120 WARNING: Previous line repeats 2 times.
08:30:40.557 T:1958323120 WARNING: JSONRPC: Could not parse type “Setting.Details.SettingList”
08:30:40.678 T:1958323120 ERROR: ExecuteAsync - Not executing non-existing script /home/osmc/.kodi/addons/script.icechannel.extn.xunitytalk/default.py
08:30:40.738 T:1958323120 WARNING: Skin has invalid include: skinshortcuts-template-widgetControl
08:30:40.739 T:1958323120 WARNING: Previous line repeats 1 times.
08:30:40.739 T:1958323120 WARNING: Skin has invalid include: skinshortcuts-mainmenu
08:30:40.739 T:1958323120 WARNING: Skin has invalid include: skinshortcuts-template-vertical
08:30:40.739 T:1958323120 WARNING: Skin has invalid include: skinshortcuts-template-reloading
08:30:40.740 T:1958323120 WARNING: Skin has invalid include: skinshortcuts-submenu
08:30:40.741 T:1958323120 WARNING: Label Formating: $VAR[widgetBackground] is not defined
08:30:40.752 T:1937765360 ERROR: GetDirectory - Error getting include
08:30:40.897 T:1958323120 NOTICE: initialize done
08:30:40.897 T:1958323120 NOTICE: Running the application…
08:30:40.911 T:1958323120 NOTICE: starting zeroconf publishing
08:30:40.939 T:1958323120 NOTICE: CWebServer[8080]: Started
08:30:40.939 T:1958323120 NOTICE: starting upnp client
08:30:40.961 T:1555035120 NOTICE: ES: Starting UDP Event server on port 9777
08:30:40.962 T:1555035120 NOTICE: UDP: Listening on port 9777 (ipv6 : false)
08:33:27.150 T:1630532592 NOTICE: URLResolver: Initializing URLResolver version: 3.0.30
08:33:27.836 T:1664087024 NOTICE: 1Channel: Service: Installed Version: 2.5.72
08:33:30.284 T:1630532592 NOTICE: Stream All The Sources: Service: Installed Version: 2.0.136
08:33:31.645 T:1664087024 NOTICE: 1Channel: Loading sqlite3 as DB engine
08:33:31.922 T:1680864240 NOTICE: [plugin.video.youtube] Startup: detected Krypton (Kodi-17.1), setting DASH_SUPPORT_BUILTIN = False, DASH_SUPPORT_ADDON = True
08:33:32.053 T:1783624688 NOTICE: Skin Helper Widgets → Backgroundservice started
08:33:32.299 T:1664087024 NOTICE: 1Channel: Service: Resetting…
08:33:32.532 T:1664087024 NOTICE: 1Channel: Service: starting…
08:33:32.760 T:1630532592 NOTICE: Stream All The Sources: Service: starting…
08:33:32.845 T:1680864240 NOTICE: Skin Helper Service → WebService - start helper webservice on port 52307
08:33:32.846 T:1830274032 NOTICE: Skin Helper Service → Skin Helper Service version 1.1.13 started
08:33:34.872 T:1622143984 NOTICE: ZT Wizard: 2017-04-14 08:33:34.871698
08:33:35.661 T:1758458864 NOTICE: [SPECTO]: ->---------- PARAMS: {‘action’: ‘service’}
08:33:37.613 T:1622143984 NOTICE: ZT Wizard: Continuing Start Up Script
08:33:37.616 T:1622143984 NOTICE: ZT Wizard: [Path Check] Started
08:33:37.617 T:1622143984 NOTICE: ZT Wizard: [Path Check] Good!
08:33:37.617 T:1622143984 NOTICE: ZT Wizard: [Auto Install Repo] Started
08:33:37.618 T:1622143984 NOTICE: ZT Wizard: [Auto Install Repo] Not Enabled
08:33:37.618 T:1622143984 NOTICE: ZT Wizard: [Auto Update Wizard] Started
08:33:39.057 T:1622143984 NOTICE: ZT Wizard: [Auto Update Wizard] No New Version v1.0.1
08:33:39.254 T:1622143984 NOTICE: ZT Wizard: [Notifications] Started
08:33:39.674 T:1622143984 NOTICE: ZT Wizard: [Notifications] id[1] Dismissed
08:33:39.675 T:1622143984 NOTICE: ZT Wizard: [Installed Check] Started
08:33:39.678 T:1622143984 NOTICE: ZT Wizard: [Installed Check] Not Enabled
08:33:39.678 T:1622143984 NOTICE: ZT Wizard: [Build Check] Started
08:33:39.679 T:1622143984 NOTICE: ZT Wizard: [Build Check] Build Installed
08:33:39.686 T:1622143984 NOTICE: ZT Wizard: [Build Check] Build Installed: Checking Updates
08:33:40.181 T:1655698416 NOTICE: Universal - An Addons Toolkit: -watchhistory- -Loading sqlite3 as DB engine version: 3.16.0
08:33:40.251 T:1655698416 NOTICE: Universal - An Addons Toolkit: -watchhistory- -DELETE FROM watch_history WHERE lastwatched < ‘2017-03-25’
08:33:40.567 T:1622143984 NOTICE: ZT Wizard: [Check Updates] [Installed Version: 1.0.2] [Current Version: 1.0.2]
08:33:40.647 T:1622143984 NOTICE: ZT Wizard: [Trakt Data] Started
08:33:40.659 T:1622143984 NOTICE: ZT Wizard: [Trakt Data] Next Auto Save isnt until: 2017-04-16 / TODAY is: 2017-04-14
08:33:40.660 T:1622143984 NOTICE: ZT Wizard: [Real Debrid Data] Started
08:33:40.660 T:1622143984 NOTICE: ZT Wizard: [Real Debrid Data] Next Auto Save isnt until: 2017-04-16 / TODAY is: 2017-04-14
08:33:40.661 T:1622143984 NOTICE: ZT Wizard: [Login Data] Started
08:33:40.661 T:1622143984 NOTICE: ZT Wizard: [Login Data] Next Auto Save isnt until: 2017-04-16 / TODAY is: 2017-04-14
08:33:40.662 T:1622143984 NOTICE: ZT Wizard: [Auto Clean Up] Started
08:33:40.779 T:1622143984 NOTICE: ZT Wizard: [Auto Clean Up] Cache: Off
08:33:40.780 T:1622143984 NOTICE: ZT Wizard: [Auto Clean Up] Old Thumbs: Off
08:33:40.780 T:1622143984 NOTICE: ZT Wizard: [Auto Clean Up] Packages: On
08:33:43.062 T:1716515824 WARNING: CSkinInfo: failed to load skin settings
