Hi Guys,
I have an small problem with my Vero 2.
When I try to shutdown my Vero 2 it stops in the shutdown process.
So I try to sleep my Vero. That works fine. But I can’t wake him up. I try all key on my remote - nothing happens.
The only way to start the vero is to plug it off and back on.
When I do an reboot all works fine…
How exactly are you trying to sleep it? There is no implemented standby support at this time.
If you select Shut Down, your Vero 2 will unmount all filesystems and halt, this is expected behaviour.
When I go to Power (at the GUI) I have the option to standby my Vero.
Yes, the Vero 2 schuld halt after the shut down. But during the shut down process it will stop and still show me some text on the TV.
I will remove the standby option, as you shouldn’t really see that.
Take a photo of the shutdown screen, but I suspect the last text is System Halted or Shutting Down. The Vero does not have an on/off switch, so it is expected to halt here
