Hi, I just noticed another problem.
I tried to play a MKV file with DD+ audio.
Kodi is on allow Passthrough (for DD+ as well) and my Denon AVR-S950H seems capable of it (regarding to the online manual). If I play the file there is no audio until I deactivate passthrough. Am I missing something?
Hard to say without debug logs.
ok, I’ll try to provide some tomorrow.
reproduce the issue
upload the log set (all configs and logs!) either using the
Log Uploader
method within the My OSMC menu in the GUI or thessh
method invoking commandgrab-logs -A
Maybe a trivial hint: DD+ aka ac3+ aka eac3 will only work if conected via HDMI (or eARC). I had a similar problem because sending AC3+ across TOSLINK failed due to its technical limitation.
Regards, Michael
