My vero 2 is connected through hdmi to a receiver which doesn’t accept stereo, so in audio settings I set the option to convert stereo to 5.1 and I have sound for stereo movies, without this option enabled no sound in stereo movie, but I have no sound in menu… I checked the option for the menu sound and it’s enabled.
Any idea?
Thx.
I find this highly unlikely. What you should be doing when using a receiver is leaving speaker setting at 2.0 and enabling passthrough.
No all is enabled on my receiver, I have the same problem with an old xbox 360 games which is 2 channel sound. It seems that the receiver doesn’t like 2 channels over hdmi, other people having the same problem:
http://www.minixforum.com/threads/receiver-hdmi-passthrough-no-audio.9606/
http://www.lesnumeriques.com/legrandforum/avis/Audio/ampli/probleme-relie-ampli-sujet_5538_1.htm
Question, for audio settings, I don’t see HDMI connection type, only analog and SPDIF which seems can be the problem: http://forum.kodi.tv/showthread.php?tid=198273
Your receiver should accept 2 channel PCM, but in the event that it doesn’t, you can use AC3 transcoding. This will ensure your AV receiver gets a 5.1 signal for playback.
I’m not sure if AC3 transcoding is extended to menu sounds. If you take a photo of your audio settings, I will double check they are best suited for your system.
I am not sure if GUI menu sounds are upmixed to 5.1. I suspect not (and that this is why you cannot hear them). I will investigate this.
