This channel used to work without a problem:
https://cdn3.wowza.com/1/MVlMdHpYbWczUC8x/bThPbTFF/hls/rmv5bbyy/2728/chunklist.m3u8
Now suddenly there is no sound on kodi in the Vero 4K+ for this channel.
Other TV channels that I have programmed do fine.
I have VLC on my windows computer and it is able to play this channel and there are no problems with the sound.
I can also play this channel in Zapette2 an android program on my Samsung tablet that gets its signals from the TVheadend in the Vero 4K+. Here I have no problem either with the sound for this channel.
I found an article that seems to describe similar problems:
Is there still a bug (in kodi or tvheadend) that causes this problem?
reproduce the issue
Logs available at https://paste.osmc.tv/kakediqaqo
I hope this helps.
Here are the logs after enabling the debug procedure.
Logs available at https://paste.osmc.tv/pahabivaje
